Removing Window Tint - BMW Forum - BimmerWerkz.com
Old 04-24-2005, 07:51 PM   #1 (permalink)
crazy91318's Avatar
crazy91318 is an unknown quantity at this point
Send a message via AIM to crazy91318 Send a message via MSN to crazy91318 Send a message via Yahoo to crazy91318
here the scoope guys that have some old crapy tint on your back windows with rear defrost and you want to get it off with out using a razor blade and messing up that rear defrost.
Try to get a corner and peel all the old tint off once you get the tint off that nasty little film that is left on the window from the tint. Go out to any hardware store and get your self a can of this stuff called 3m Citrus Base cleaner and one of those little sponges with the scrubby part on the bottom. Once you get the tint off spray the window down and start scrubing it takes a bit to do and the spray is realy stong but it works it will take that sticky fillm off your window with out messing up your rear defrost
crazy91318 is offline   Reply With Quote
Old 04-25-2005, 11:09 PM   #2 (permalink)
Car: 95 E36 318, E30 325e
h4rdwire is an unknown quantity at this point
Send a message via AIM to h4rdwire Send a message via MSN to h4rdwire
Eastiest way is to get a heat gun, wet towel and basically get moisture under it and it peels nicely, but with the film. Nothing Acetone can't clean up then dry and windex or whatever.
BUT, note do not use heat gun on the tint DRY or else it'll slightly crimp up and STICK to the glass even more drying on it or ....getting BAKED on the windshield
h4rdwire is offline   Reply With Quote
Help - Removing The Window Regulator On My 99 528i supercal29 5-Series (E12,E28, E34, E39, E60) 4 03-19-2005 12:51 PM
Window Tint Question Robdrmer1016 3-Series (E36) 7 04-28-2004 07:30 AM
Window Tint... college_cars 3-Series (E46, E90) 9 04-13-2004 08:06 AM
Window Tint E46BMWRIMS 3-Series (E46, E90) 1 01-22-2004 04:10 PM
