Remove Seat to Replace Seat Belt Receptacle? - BMW Forum - BimmerWerkz.com
Old 02-10-2008, 12:55 PM   #1 (permalink)
Redhaze737 is an unknown quantity at this point
I need to replace the drivers side Seat belt receptacle. It's bolted to the inside of the seat with very little room to access the short bolt although it may be possible with an end wrench. It looks like it would be easier to remove the seat. Has anyone ever replaced the seat belt receptacle and/or can you direct me to instructions for removing the seat?
Or any suggestions are welcome.
Aloha.
Redhaze737 is offline   Reply With Quote
Old 02-11-2008, 12:04 PM   #2 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I don't know about the seat belt....but the seats are easy as pie to remove...
there are 4 nuts...I believe size 17 mm...two in the front of the seats and two in the back. Slide the seat all the way to the back and take out the front nuts. Then slide the seat forward and take out the back nuts.....done and done.
yammahamma is offline   Reply With Quote
Old 02-11-2008, 12:14 PM   #3 (permalink)
Thanks for the help. I'll see if I can get to it by raising the seat up as high as it will go. Otherwise I'll take it out.
Old 02-20-2008, 09:54 AM   #4 (permalink)
Car: 1987 bmw 325is
Beemer_Bandit_666 is on a distinguished road
yeah it would definitly be easyer to remove the seat for working room
to remove the seat, just slide it either forward or backwards, depending on where you feel like starting. there may be plastic caps over the heads of the bolts, but those come off easy enough with an interior clip remover or a flathead screwdriver. if memory serves me correctly theres two nuts in the front of the seat and two bolts in the rear. after thos are out the seat should just lift right out of the car
as far as the seatbelt, it should just be one bolt on the bottom of the upper recepticle and one down under the belt roll
and the seat bolts are 15mm, unless theyve been removed and replaced by somthing/someone else
Beemer_Bandit_666 is offline   Reply With Quote
Old 05-13-2008, 09:52 PM   #5 (permalink)
I finally got to this project. I took the seat out and replaced the seat belt clip. It took about 10 minutes. Easy as pie. Thanks. Now if I can just get the driver's side door lock to work I'm golden. Well, until the next issue.
Old 10-15-2010, 06:30 PM   #6 (permalink)
E32Beemmer is on a distinguished road
Hello, first time post. I'm removing the front seats to my 88-735i. I've read your intructions on how to remove them, and it sounds exactly like the Chiltons manual. But, for the life of me, I don't understand which 4 bolts? The manual shows no figures (pictures) and they state to remove the seat- track from the base by removing these 4 bolts you speak of. I removed 2 bolts from the back that fasten the base to the floor board, and then slipped the base off the 2 hooks that secure the front of the base, and took the seat out. The manual says by removing these 4 bolts, the base remains to the floor, and then you can remove it if desired.
What am I missing? Would appreciate some clearification on these intructions.
Thank you, CJ
E32Beemmer is offline   Reply With Quote
Old 01-13-2012, 06:42 PM   #7 (permalink)
hoopster is on a distinguished road
The Driver Side Seat Belt locked in the closed position when I stopped to get fuel at Costco....I couldn't get out of the car unless I crawled out of the seat...I decided to go home to do that!! It was hilarious because I am 6'5" tall. I'm happy no one saw me!! I was able to reorder a new Seat Belt receptacle; took the seat out to take the old out and install the new one....Just a funny story!!
hoopster is offline   Reply With Quote
Old 01-14-2012, 11:50 AM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Hahahaha You should've got a friend to video that for us
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Remove back seat E39 (Tourer) zc1 5-Series (E12,E28, E34, E39, E60) 0 09-10-2007 07:35 AM
How to remove leather seat back and bottom from seat frame mitch.smith 3-Series (E36) 0 07-09-2007 10:19 AM
Passenger Side Seat Belt Install YoungExec728 3-Series (E36) 1 10-13-2004 12:34 AM
Seat belt warning Yellanugen 5-Series (E12,E28, E34, E39, E60) 0 09-16-2004 09:36 AM
Seat belt retractor stuck fastlaner 3-Series (E46, E90) 3 07-27-2004 08:00 PM
