Rebuilding My 325i head - BMW Forum - BimmerWerkz.com
Old 08-04-2006, 04:43 AM   #1 (permalink)
Majin's Avatar
Majin is an unknown quantity at this point
I need to know how to remove the torx bolt on the camshaft gear with out damaging the outer areas of the head. The head is already out of the car.
Majin is offline   Reply With Quote
Old 08-04-2006, 05:51 PM   #2 (permalink)
Car: Opening soon:
Take a section of the old timing belt and a O2 sensor socket, cut the timing belt so that you have enough to wrap around the sprocket then mesh the timing belt teeth together then slip it into the O2 sensor slot then roll it up then use a breaker bar to hold it in place so that you can break the bolt loose. Sometimes you can pinch the timing belt together and hold it with channel locks so that you can undo the bolt too.
Good luck.
Wtb: 325i Head e30325ic 3-Series (E21, E30) 2 02-23-2005 02:09 PM
325i Rebuilt Head Applications?? Excelerate 3-Series (E36) 10 11-19-2004 10:11 PM
Head Lamp: 2004 325i Versus 325ci postrio 3-Series (E46, E90) 1 11-06-2004 09:46 PM
stock tapedeck head unit from 325i for sale black325 Classifieds Sell & Buy 0 08-01-2004 07:16 PM
1990 325i cracked head, what are options? piecemaster 3-Series (E21, E30) 1 10-23-2003 03:50 PM
