Rear Transmission Mount ? - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 06-08-2004, 09:22 AM Thread Starter
drwambo is an unknown quantity at this point
Hi all,
A couple of questions, actually.
Need to replace Passenger side (and driver's while I'm at it) Tranny mounts. Can you lower the tranny at all without pulling the drive shaft? It's a major pain on my back due to ability to lift....
Thanks,
Dougals
drwambo is offline
post #2 of 6 (permalink) Old 06-09-2004, 09:19 PM
Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough Starmavin is a jewel in the rough
First off, what are you working on?
Starmavin is offline
post #3 of 6 (permalink) Old 06-10-2004, 09:14 AM Thread Starter
A couple of things.
1) Shifter bushing to transmission. Mine is sloppy, and I'm hoping to make the changeover without pulling the drive shaft again because it's tough for me to physically lift the drive shaft due to back problems.. I have to drop the back of the tranny because my hands are too big to fit in the tight area above it to pull the clip and pin.
2) One of the rear transmission mounts pulled out of the slot on the underside of the car. I'm hoping that I can bend the slot back up and ensure that the bolts are very tight. Otherwise, i'm not sure how to fix that. The slot underneath seems like a really bad way to capture the tranny mount bolts. Perhaps it just needs to be put back in the slot and tightened down real well, but I;m not sure at this point.
ANy help here would be appreciated.
Oh and DUUUUUHHHHH.. 84 325E......
drwambo is offline
post #4 of 6 (permalink) Old 06-11-2004, 10:13 PM
That should be the E30 body. If the shifter is slopy, it's most likely the shifter plate mounts, these 3 rubber mounts (you'll have to remove the drive shaft to get at it) just wear out. Even quicker if soaked in oil.
If the metal bracket is bent, check the engine mounts to see if they are good. The trany mount bracket bolts slide in rails built in the body, I advise that when the mounts are bolted in place on the trany to slide the bracket so the slots slightly push against the mounts then tighten both the body and trany mounts down. As far as a good idea on how they are built, I do beg to differ. However, it does make life easier when you change them.
Good luck.
post #5 of 6 (permalink) Old 06-12-2004, 05:05 AM
takaaco's Avatar
takaaco is an unknown quantity at this point
Send a message via Yahoo to takaaco
if your just doing the tranny mounts
yes you can do it with out removeing the drive shaft
[<img src='
takaaco is offline
post #6 of 6 (permalink) Old 06-14-2004, 11:35 AM Thread Starter
Thanks,
I figured it out. Still trying to get the #@&*(@ Shifter bushing off. Tough to do by feel. About ready to just PAY somone to do it much as that pains me!
AARGH
drwambo is offline
Rear Shock Mount Failure redd90 3-Series (E36) 7 07-05-2005 02:59 PM
Just Blew A Rear Strut Mount..any Help Out There? 98three28i 3-Series (E36) 5 06-23-2005 08:04 PM
Ireland Engineering Rear Shock Mount (e30, E36, E Autotechnica Classifieds Sell & Buy 2 01-05-2005 07:03 AM
