Rear Tilt - BMW Forum - BimmerWerkz.com
Old 10-06-2006, 10:42 PM   #1 (permalink)
Car: 86 325es
Fauvay is on a distinguished road
Rear Tilt
I know, the title seems odd. If you look at the rear of my car, the right side sits higher then the left side. This was something I noticed before I swapped out suspension components and it still does it. I just did the subframe bushings as well and still have it. Is it possible that the rear trailing arm bushings are causing this? As far as I know they are original and I intend to swap them out. Any help would be great.
Fauvay is offline   Reply With Quote
Old 10-06-2006, 11:01 PM   #2 (permalink)
egk2 is an unknown quantity at this point
Not odd at all, many people have the same problem but can't pinpoint it.
2.8L M20 Stroker
egk2 is offline   Reply With Quote
Old 10-07-2006, 06:18 AM   #3 (permalink)
Car: 86 325es
egk, I posted this over at BF and didn't get very far. E30tech had a little more insight. You obviuosly have a lot of experience with these cars, is it possible it could be due to lack of a factory battery? I'm sure BMW factored that in to the suspension geometry and am thinking that aftermarket batteries don't weigh as much?
BTW, you have created an amazing car. Glad to see you are on these forums as well. Things seem a little more civil over here.
Old 10-07-2006, 09:57 AM   #4 (permalink)
Nah, I have a factory battery in my car and it is a hair lower on the left,
subframe bushing are still good, spring pads are new, springs are new, rsm's new, etc..., I had an e36 that rubbed only on the left rear as well , I just live with it, only I notice it.
2.8L M20 Stroker
Cant access to rear trunk for battery location,,, Stuggie 3-Series (E36) 11 01-01-2006 05:00 AM
Excessive rear wheel tilt Abbey Normal 3-Series (E21, E30) 9 09-21-2004 08:42 AM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
