Rear end chattering and clanking sometimes - BMW Forum - BimmerWerkz.com
Old 03-31-2007, 07:21 AM   #1 (permalink)
Oxy- is an unknown quantity at this point
Hello all!
I've been out early morning today to open summer driving season Had done a few sporty drifting laps and after some time when returning home I was faced with these new awful sounds coming from the end of my 325e 86':
1) when cruising (no gear engaged) >40kmh a strong chattering and a feel of vibration emerges from the rear of the car used:
if I engage a gear and accelerate or decelerate (stopping car with an engine) it almost disappears;
if I press the brakes - it almost disappears;
if I change the gear up/down, at the time when there is no gear I hear the chattering again.
Shortly, it seems that the chattering is coming when there is no tension in the drivetrain.
2) when starting from a standstill I hear CLANK! (or BANG!) : then the car runs fine (until I reach middle speeds)...
I have inserted a viscous LSD differential a few years ago. Also had done a major rebuild of it (in order to make more lock) two years ago. And it worked great. Hope it's not a diff... I would suspect the diffs U joint, but then why it appears when cruising and not viceversa?
Hope for your help,
Thanks!
Oxy-
Oxy- is offline   Reply With Quote
Old 03-31-2007, 01:01 PM   #2 (permalink)
Wouw... I got under the car, everything arround the diff seemed fine, then jacked up one wheel, then another and what a surprise - it was loose! The wheel bolts where loose Everything solved after just tightening them!
Old 03-31-2007, 02:07 PM   #3 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
wow, good thing you were listening to your car!
My BMW Blog
Old 03-31-2007, 09:33 PM   #4 (permalink)
Car: Opening soon:
Sounds all most like a bad or broken trans mount. And/or it could be that your differential or it's mount has come loose from the rear cross member and/or body...
