Rear Defrost Window Half Working? - BMW Forum - BimmerWerkz.com
Old 11-21-2004, 09:52 AM   #1 (permalink)
Paraklas's Avatar
Car: 2001 E46 320ci with ESS TS2
Paraklas is an unknown quantity at this point
My problem is simple...
When the rear defrost switch is turned on, only two-three copper lines actually work on the window. Anyone with similar problem? maybe a solution?
Thanks
Paraklas is offline   Reply With Quote
Old 11-23-2004, 03:00 PM   #2 (permalink)
only real answer is a new window you can buy stuff that piant over the breaks in the lines but it's not great
Old 11-23-2004, 03:57 PM   #3 (permalink)
W00T
Numark318i's Avatar
yea i got the same problem....anyone with an answer?
Really i would need a whole new rear window?
damit.
only 1 of mine work.
Old 11-23-2004, 07:04 PM   #4 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
Have you guys tried asking your question on other forums?
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Old 11-23-2004, 07:29 PM   #5 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
damit.
[snapback]236156[/snapback]
have you brought out the ole faithful OHM-METER and checked continuity ?
also the ole 9 dollar cheapy ohm meter would isolate the broken spot very accurately and without having to tear apart all of your car... jsut the possessed parts...
and even further if it is on the window (and you dont mind a little more visible wire) it is possible tto jump the broken parts to the good parts ...
and pushing the envelope to a new hieght would be to buy a 10 dollar electrical de-fogger for the windsheild and rig it to the back. you can cut off the cig. lighter connector and wire it to a direct llink providing you add the 99cent 5 amp fuse...
really easy with the right tools ...
and speaking of the tools if you dont have a OHM-METER yet than i strongly suggest the kind with the needle .. NOT digital...because one reason..
itll vork without batteries on voltage and can test batteries
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Old 11-23-2004, 07:32 PM   #6 (permalink)
Speedy-325is's Avatar
damit.
i have one that works..........$$$$
Old 11-23-2004, 09:03 PM   #7 (permalink)
idanity's Avatar
Originally posted by Speedy-325is+Nov 23 2004, 07:32 PM--><div class='quotetop'>QUOTE(Speedy-325is @ Nov 23 2004, 07:32 PM)</div><div class='quotemain'><!--QuoteBegin-Numark318i@Nov 23 2004, 03:57 PM
damit.
[snapback]236290[/snapback]
[/b][/quote]
well the GOOD NEWS = one wire works...
so you have "continuity " to the window and the fuse is okay..
now is it the top or bottom wire, from there look closely for any cuts or damage and if your really good melt down a gold earing and make a jumper wire across it.
or roll down your windows...
also buy a OHM=METER and fallow the currents until they fail and make sure you check both sides as its a D.C. voltage thing...
dont forget to celebrate the working of the one...poor little wire all by itself with a whole window to defrost...must be a fighter B)
Old 11-27-2004, 12:15 PM   #8 (permalink)
All wheels rolling is an unknown quantity at this point
That's better then mine... it doesn't work at all... I have to crnaks the heat... when it works to get the top to defrost. I've tried everything. I think it's in the wiring...
P.
All wheels rolling is offline   Reply With Quote
Old 11-27-2004, 11:07 PM   #9 (permalink)
P.
[snapback]238395[/snapback]
Have you tried replacing the switch?
735 1998, rear window roller blinds phil 1,6,7,8 - Series and Mini Cooper 3 02-08-2011 05:02 AM
used 528: rear window & cam belt question jcmky 5-Series (E12,E28, E34, E39, E60) 1 10-16-2005 04:37 PM
Very Hot Spot On Wagon/touring Rear Window nv325xiT 3-Series (E46, E90) 2 01-25-2005 03:16 AM
Rear power window failure Minardi 5-Series (E12,E28, E34, E39, E60) 2 08-14-2004 01:23 AM
AirCon, Heated Rear Window Permanently Lit mrJones 3-Series (E36) 0 10-23-2003 05:41 PM
