ram air home made? - BMW Forum - BimmerWerkz.com
Old 03-29-2009, 10:51 PM   #1 (permalink)
beamerboy325is's Avatar
beamerboy325is is on a distinguished road
Question ram air home made?
Hi guys I'm trying to figure out some stuff about cold air intake systems I know theres a lot of crappy systems out there that claim big hp but its also big$$$.So I had an idea maybe its even something you guys mite want to try yourself.So lets get started, I have a 1990 325is mtech bmw ,I dont want to hack away at the air box I'm trying to keep the cars extiorior and interior original as possible,its black on black leather and loaded with features anyway I was thinking about making a custom ram air from an air scoop from an f150 that I had removed before I junked the truck,the scoop measures 6" wide x 1 1/2 " tall and has a round 5" tube thats a good 12'' in length total that points going up.So I was thinking of mounting it somewhere just under the lower front valance so it will be showing just a bit but not affecting the look in a bad way then I want to attach this to my stock air box inlet and add a k&n filter,does anybody think this will work Ive seen it on hotrod tv I think its a good idea??
beamerboy325is is offline   Reply With Quote
Old 03-29-2009, 11:07 PM   #2 (permalink)
Can we see a pic of this scoop? I'm not sure there's any way to make it look good.
Old 03-29-2009, 11:20 PM   #3 (permalink)
I will take pic of it tomorow its acually very thin in hight and only 6'' wide so it would be hiden well.
Old 03-30-2009, 02:36 PM   #4 (permalink)
Rfitz25's Avatar
Rfitz25 is on a distinguished road
I just bought the bavauto kit for the bracket put on a bigger K&N
save the old airbox for smog test
remove the second headlight lowbeam
then built a heat shield from sheetmetal and covered it in dynamat use pipe insulation to seal to the hood,
(closed lid on custom box is better implimentastion Ive seen)
works like a champ, wooooot...
Cheers,
Richard Fitz
'87 325is Delphin Metalic
Rfitz25 is offline   Reply With Quote
Old 03-30-2009, 03:28 PM   #5 (permalink)
Rfitz25's Avatar
you can drill out more of the grilll too
also some use the is brake ducts
but if you get too low you'll pick up alot of crud ,water, marbles etc
why cant i edit my post?
hm now i can?
Cheers,
Richard Fitz
Old 03-30-2009, 07:09 PM   #6 (permalink)
na, that won't work....
silversled is offline   Reply With Quote
Old 03-30-2009, 11:08 PM   #7 (permalink)
Kool guys your ideas are all great ,so I,m going to think about it look around and see my options and go from there, thanks for the info.
made it home TIM 325I 3-Series (E36) 1 01-05-2006 05:59 PM
Korman Ram Air Intake Foehammer101 3-Series (E36) 1 07-24-2004 01:08 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
Ram Air For Our Bimmers... WickedBimmer 3-Series (E36) 2 01-27-2004 06:04 PM
High Beam ram air... Stuka 5-Series (E12,E28, E34, E39, E60) 5 01-12-2004 12:09 PM
