Radiator Fan Switch - BMW Forum - BimmerWerkz.com
Old 06-08-2005, 08:15 AM   #1 (permalink)
BMW@JMU's Avatar
BMW@JMU is an unknown quantity at this point
Has anyone here upgraded their radiator fan switch from the 91 degree to the 82 degree? I was wondering if it was really worth it and if it would be necessary.
Currently my low fan switch does not work and I am planning on autocrossing my car this summer=possible overheating. Should I just go with the stock 91 degree or the lower temp?
Also, should I keep my 99 degree or get a lower temp for that too?
-1985 325e - 5000 RPM's of Fury
BMW@JMU is offline   Reply With Quote
Old 06-08-2005, 08:19 PM   #2 (permalink)
offabroadway is an unknown quantity at this point
Dude, I love the catchphrase. 5000rpms of fury. As a fellow E owner, I agree.
Am I the only one confused about the fan, however? My E has a fan bolted to the front of the engine, and it spins with the engine. Don't have any other fans on there. I don't think it's electrically actuated.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 06-09-2005, 10:21 AM   #3 (permalink)
BMW@JMU's Avatar
[snapback]351872[/snapback]
There is also an electric fan in front of your radiator that will turn on low when your coolant level reaches 91F and then high at 99F. I was wondering if I should get a temp. switch that will turn the low on at 82F.
Old 06-09-2005, 10:36 AM   #4 (permalink)
Ah.
Well, if your aim is autocross, why not? Could only help.
Old 06-09-2005, 09:06 PM   #5 (permalink)
BMW@JMU's Avatar
The only problem with using the lower temperature is that the fan will most likely be on which will be using the alternator more and thus taking away from the power getting to the wheels. I'm still undecided though.
DIY Push Start Ignition El Presidente 3-Series (E36) 161 03-04-2011 03:13 PM
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Changing The Light Bulb In Headlight Switch ben_t 5-Series (E12,E28, E34, E39, E60) 2 06-09-2005 08:21 AM
Wiper Switch dsstultz 3-Series (E21, E30) 1 02-17-2005 09:45 PM
Instrument panel switch jackinsac 3-Series (E21, E30) 4 03-16-2004 05:27 PM
