Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 05-29-2008, 06:54 PM   #1 (permalink)
Photos: 0
darion45405 is on a distinguished road
Smile questions about an 85 325e (e30)
so i just traded a blazer for this car, and so far i am loving it (even with the issues). the problem is i know absolutely NOTHING about a bmw.so here are my questions.
1. the turn signals both work only in the morning, in the afternoon the right one stays on solid and the left blinks fast and is very dim in the front. i just replaced both bulbs. could it still be the blinker relay in the column?
2. the check light on the cluster constantly blinks. if it is like the chevy obd1 then it would be blinking 1, 1, 1, and so on. what is that and is there a way to check it without a scan tool (like the chevy system)?
3. on the information thing next the radio that tells you stuff like average mpg and stuff. how do you turn that from metric to standard?
4. i am getting a strange noise from the back, it sounds like the fuel pump whirring but it just seems really loud for a fuel pump.
5. last one. where do you add clutch fluid at? i have looked all over the place and i cant find the reservoir.
also any other information you can tell me such as quirks common to these cars would be very appreciated. thank you.
darion45405 is offline   Reply With Quote
Old 05-29-2008, 07:40 PM   #2 (permalink)
Nick_318is's Avatar
Car: 1991 BMW 318is, 2007 Mazdaspeed3
Photos: 0
Nick_318is is on a distinguished road
Send a message via AIM to Nick_318is
Here is what I can say:
1. Did you only replace front bulbs, it might be the rears and or a relay.
2. You can try this test and see if you get any codes. Pelican Technical Article: Reading BMW Fuel Injection Fault Codes
5. The brake fluid reservoir , the brakes and clutch both get fluid from it.
The others i'm not sure on and hopefully someone here can help you out with those.
Nick_318is is offline   Reply With Quote
Old 05-29-2008, 08:25 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
1. probs looks to me like a poor contact with bulb at the socket. I suggest you clean all sockets before installing the bulbs. The "blinks very fast" - that is an indication that RELAY WORKS but one of the bulbs(or it's connection) is malfunctioning. If it blinks fast on the left, the concentrate ur efforts on the left. ;-)
2. Nick is correct. Pelican articles ca give you a world of info on bimmer tech. Note though that the on-board diagnostics of BMW will work ONLY if the internal battery(behind the instrument cluster) is functioning fine.
3. metric to standard. try and get hold of an owner's manual. it will provide you the sequence that u need to proceed with.
4. if press your ear to the body closest to the tank, u should be ale to discern better. fuel pump that is audible is not normal, and u may want to replace it before it goes bad on you on the road.
E30's are fun to drive... Welcome to the club :-D
Old 05-29-2008, 09:55 PM   #4 (permalink)
Photos: 0
Thumbs up
thank you for all the info. i went to the pelican sight it was very informative. the only owners manual i could find was on e-bay, and they wanted like $170. i was able to find out how to reset the onboard computer from another site i found on this forum. i will try to figure out the turn signal thing this weekend. and yes even with the bad sway bar bushings i already love this car.
Old 05-29-2008, 10:51 PM   #5 (permalink)
Car: 1985 325E 144K 1990 525I 201K
Photos: 0
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
3. its a small pencil size input for my OBC to change from standard to metric. you just tap it once or twice. My 90 525I changes with actual S/ Reset button.
on the lights it maybe turn signal relay. i have found that disconnects can occur on the lights themselves<<perhaps by aggressively driving . check terminals for light bulbs and electrical connections. be careful of turn signal switch might be bad or check connection. ive had to change mine. check for relay to hazard light. if u press the hazard just slightly on either left or right side you might be able to get a blinker to come on. this mostly is an indication of a bad switch.
5. i dont believe the brake fluid reservoir is for the clutch, or manual transmission?? is that right? or is it under car some where??
pinnaclebass is offline   Reply With Quote
Old 05-30-2008, 09:54 AM   #6 (permalink)
Nick_318is's Avatar
Photos: 0
I'm sure the clutch fluid is the brake fluid, see this DIY:
e30tech.com
Old 05-30-2008, 05:43 PM   #7 (permalink)
Car: 1987 325 ES
Photos: 0
SandiegoStemcells is on a distinguished road
I am also new to the "Beemer club." One thing you have to get is a Bentley Manual.
Amazon.com for ~$50 new... you can find cheaper ones on there used....
SandiegoStemcells is offline   Reply With Quote
Old 05-30-2008, 06:51 PM   #8 (permalink)
Teh whore
AlpineSixAndSeven's Avatar
Car: 1986 325es, 1987 635CSi, 1976 Benz
Photos: 0
Clean all the connections at the bulbs and makesure their all the same brand.. i had an issue like this with my 740.....
..... that isn't a CEL it is telling you to Check the "check board" it is the little bored with the red leds that tells you when your lights are out or fluids are low.... click the button on it and the Check will stop blinking because you checked it (also check the item thats lite up....)
as Pinn said "its a small pencil size input for my OBC to change from standard to metric. you just tap it once or twice" my car had to be in the range or mpg / liters :100 km's
.... why? it is low? it is the same res. as the brake fluid use atleast dot 3...
if you look at the side of the res. there will be a hose comming off it and that goes to the Clutch master Cylinder....
Your welcome and welcome! glad to see new People!
Originally Posted by drz View Post
I'll never be bound to no man by means of a piece of paper
AlpineSixAndSeven is online now   Reply With Quote
Old 05-31-2008, 10:15 AM   #9 (permalink)
teh lifesaver
german-speed-demon's Avatar
Car: a japanese econobox
Photos: 3
Send a message via AIM to german-speed-demon Send a message via Yahoo to german-speed-demon
Greets. theboys seem to have gotten most of the stuff already answered for you, so i'll just stay kinda quiet.
R.I.P fast 6
vB code is On
E30 turbo 325e!!! E30bigturbo Forced Induction 9 10-29-2007 04:48 PM
Rims for E30 325e.... Enthuziast 3-Series (E21, E30) 7 10-19-2005 01:35 AM
325e Engine Questions offabroadway 3-Series (E21, E30) 4 06-08-2005 06:07 PM
1985 325e Questions offabroadway 3-Series (E21, E30) 8 03-13-2005 05:30 PM
RIP 84 E30 325e gotKRAUT 3-Series (E21, E30) 13 09-24-2004 11:22 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
