Punctured Oil Pan - BMW Forum - BimmerWerkz.com
Old 04-16-2005, 01:22 PM   #1 (permalink)
csrnumber1 is an unknown quantity at this point
Ya...uh my oil pan got punctured, not quite sure y it had to happen to me though...hahaha. However, how long does it take to remove the oil pan from underneath the car and if an '87 325is oil pan will fit an '85 325e car (if i take it from one and put it in another)?[/b] please answer asap! thanx!
<span style='font-family:Arial'><span style='font-size:8pt;line-height:100%'><span style='color:blue'><div class='quotetop'>QUOTE</div><div class='quotemain'>Extreme!</div></span></span></span>[/FONT]
csrnumber1 is offline   Reply With Quote
Old 04-16-2005, 04:14 PM   #2 (permalink)
i dont think they are interchangable but they could be, do some research.
it isnt that hard, you can un bolt the mounts and jack up the engine, or i think you can unbolt the subframe and it'll come down some.
Old 04-16-2005, 09:19 PM   #3 (permalink)
joshh is an unknown quantity at this point
Part # 11131720754
It is the same for the E and the I and I'm sure you can call the dealer and ask for the IS.
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Old 04-18-2005, 01:20 AM   #4 (permalink)
draculia is an unknown quantity at this point
the e pan will work fine.
its not as easy as some other cars, but still its not too big of a deal.
draculia is offline   Reply With Quote
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
what transmission and differential oil should i use? träumer 3-Series (E21, E30) 6 10-10-2005 01:42 PM
