Pulse Sensors...... - BMW Forum - BimmerWerkz.com
Old 11-29-2004, 07:41 PM   #1 (permalink)
mosyslack is an unknown quantity at this point
What kind of problems come up if a pulse sensor goes bad? Or speed sensor? I have a 1989 325i and lately there has been a stutter of sorts while the engine runs. There is slight hesitation, and lack of power, but the engine has a constant miss during all operations (idle, partial, full throttle). There is good fuel pressure, the fuel pres reg is ok, no vacuum leaks (that I have found..hehe), new spark plugs, and they all seem to be firing.
Is there any way of checking the timing? Everything that I have seen says that it is a self contained process, with no way of adjusting. ANY info would be very helpful....thank you all.
dave
mosyslack is offline   Reply With Quote
Old 11-29-2004, 09:11 PM   #2 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
dave
[snapback]239754[/snapback]
i own a 89 325i conv. and had the same problem and it may be very simple.
first does it do this MORE-SO when the tank is almost empty?>
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Old 11-29-2004, 10:35 PM   #3 (permalink)
unfortunately, nope....the tank is at least 3/4 full! What do you have in mind?
dave
Old 11-29-2004, 11:13 PM   #4 (permalink)
idanity's Avatar
+ mine does that too, somedays i have a jerking effect useally when im cruising along at a pace and sometimes when i just top a hill and start to decline down the other side. jerk, jerk, hesitate jerk, then goes away.
THE GOOD NEWS = most likely not
NOT injectors,
NOT timing, ( or most likely just replace every 40,000mi.)
it may be the exhaust manifold...
it may be the air-intake needs cleaning
some of the ABOVE PROBLEM may be due to other things besides fuel and intake.
ive got the factory exhaust and when doing the HOT-SOAK i noticed some smoke coming from the exhaust manifold...
this indicates a major loss of power and perhaps the culprit of the jerking i have in all gears, with a full tank or empty and more often(i think) on days when the weather competes with BACKPRESSURE created by tiny hairline cracks in my manifold.
again if i had not ever done the hot-soak i would not have noticed the leak.
and since i did.
im now going with headers and a catback... anyone please help me find one ...
but your main problem could be a simple vacuum hose, that controls the fuel regulator , the air filter, a crack in any air intake housing (squeeze the big black hose in-between the airflow meter and the intake manifold --simple fix), also could be a
- loose ground wire
- poorly adjusted idle
- rotor, cap, wires,...... rotor, may have water in it
- coil
- fuel grade ... ...........higher or lower octane .. mine runs best on 87 oct.
- fuel filter
- fuel hoses,
- fuel gas cap,........... the seal may be old
- fuel pressure,
- fuel regulator ........ easy 10 minute-$65 dollar fix,
- vacuum hoses .. ...10 cents a foot, need one foot
- exhaust ...................back pressure
- catalitic converter,,,.. im counting the days for a cat-back system 300.00
i also pulled out the fuel pump and it was scary at first but really easy, i may buy a high end one because it will be a breaze to replace but the exhaust is first.
plus i heard i could get upto 30 more horsepower from the cat-back and headers.
anyways start with the cheap stuff and report here for great advice from the bmw fanatics.
HELP..!!!.....removal of air pulse valve from e21 323iguy 3-Series (E21, E30) 0 09-06-2005 12:37 AM
O2 Sensors fushuman 3-Series (E36) 5 02-16-2005 07:22 PM
Location Of O2 Sensors J.Bassler 3-Series (E36) 7 02-04-2005 02:12 PM
Wheel Sensors tgwinn5 5-Series (E12,E28, E34, E39, E60) 2 11-28-2004 10:15 PM
318i brake sensor (and other sensors) abajaj 3-Series (E46, E90) 1 05-05-2004 11:16 AM
