Problem with radiator fan - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 12-26-2005, 12:32 PM Thread Starter
Slow325i is on a distinguished road
Send a message via AIM to Slow325i
Last night i was checking something under the hood with engine runing when i heard some noise coming from lower radiator area
I look at better and i find out that plastic that goes aroundfan is for some reason pushed out of place
I was wandering did anyone remove this plastic piece because i could just remove it or I can fix it
I'm from Bosnia / Europe ,4 years ago i move to Erie , PA USA ,my English is sux ,so please don't critize me
89 BMW 325i coupe
88 325ix
94 Mustang GT vert
87 BMW M3 swap(clone M3)
(Back in Bosnia)
Slow325i is offline
post #2 of 4 (permalink) Old 12-26-2005, 02:02 PM
Festivus yes, bagels no..
yammahamma's Avatar
yammahamma is a splendid one to behold yammahamma is a splendid one to behold yammahamma is a splendid one to behold yammahamma is a splendid one to behold yammahamma is a splendid one to behold yammahamma is a splendid one to behold yammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I just got done replacing my timing belt and to do that I had to remove the radiator and that plastic piece that's around the fan.
I'm pretty sure this plastic piece helps channel the air through the radiator and helps keep the temp down...so I'm not sure if just removing it is the best idea.
I'm think you have to take the radiator out along with the plastic piece (you can unhook the plastic piece from the radiator but there won't be enough room to pull it out unless the radiator is taken out)
to remove the plastic piece from the radiator there are two plastic "rivets" that hold it to the radiator. There are located at the top in each corner of the plastic piece. Each "rivet" has two peices--there's a little plastic pin in the center of the "rivet" that must be pulled out first to allow the rest of it to come out--once those two rivets are out then the plastice piece is now separated. There are two slots at the bottom of the radiator that the plastic piece rests in--and upward pull will take it out of those.
but like I said, I couldn't get it out with out removing the radiator along with it....but you can try if you want...good luck!
yammahamma is offline
post #3 of 4 (permalink) Old 12-26-2005, 03:19 PM Thread Starter
Problem fixed with 3 zip ties, 3 plasctis screws/rivets was missin on shroud ,so i just put zip ties and its tight like never
Thanks anyway
89 BMW 325i coupe
88 325ix
94 Mustang GT vert
(Back in Bosnia)
Slow325i is offline
post #4 of 4 (permalink) Old 12-26-2005, 10:35 PM
Kowalski's Avatar
you can just take the fan off, its 4 13 mm bolts... saves removal of the radiator.
264* roatation and 388 lift
Kowalski is offline
Drive Shaft Problem... 97alpineM3 3-Series (E36) 9 12-02-2005 03:33 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
Alpine 9835 Fm Tuner Problem ultraviolet353 Audio and Electronics 7 09-22-2004 11:09 PM
