Problem!!! - BMW Forum - BimmerWerkz.com
Old 01-03-2005, 10:45 AM   #1 (permalink)
htp.bmw is an unknown quantity at this point
Send a message via MSN to htp.bmw
I have this problem... when my 325i conv. goes over 5000rpm it hesitates and shakes the car and doesnt allow it to pass the 5000rpm mark and i have to let it change gears there
what can i do to fix it...
<span style='color:blue'>Proud Member of the Top Down Club</span>
<img src='http://www.joe-ks.com/archives/WithoutWindows.jpg' border='0' alt='user posted image' />
.:.HTP.:.
htp.bmw is offline   Reply With Quote
Old 01-03-2005, 11:52 AM   #2 (permalink)
Hypnogaja's Avatar
Hypnogaja is an unknown quantity at this point
-your timing is off (that's what happened to me, too far advanced)
-there is something wrong with your your fuel system/ check fuel pressure
Hypnogaja is offline   Reply With Quote
Old 01-03-2005, 03:11 PM   #3 (permalink)
hawkmoon36's Avatar
hawkmoon36 is an unknown quantity at this point
Send a message via Yahoo to hawkmoon36
Could be the rev limiter. My car does the same thing.
Member of the: over 100,000 miles club
Member of the: 3 Pedal Club
Member of the: 19 years old and still going strong Club
hawkmoon36 is offline   Reply With Quote
Old 01-03-2005, 05:37 PM   #4 (permalink)
if its the fuel pressure how do i check it..
can i just remove the rev limiter?...
im just gonna check the timing
.:.HTP.:.
Old 01-04-2005, 07:49 AM   #5 (permalink)
hawkmoon36's Avatar
The rev limit is electronically controlled. Most chip swaps remove that. To be honest, I could never understand the limit on the 3s. My '86 325es redlines at 4500, but my old 533 redlined at 5500.
Old 01-04-2005, 09:12 AM   #6 (permalink)
TMac325is's Avatar
get a tuneup?
Old 01-04-2005, 09:14 AM   #7 (permalink)
TMac325is's Avatar
and if you have a 325i convertible, and its an e36, then your rev limiter will not kick in until 6500 rpm
Old 01-04-2005, 10:08 AM   #8 (permalink)
is it possible that the rev limiter is broken?
.:.HTP.:.
Old 01-04-2005, 02:54 PM   #9 (permalink)
Hypnogaja's Avatar
Is it backfiring at the upper RPMs too? That is a sign of the engine running too lean (not enough fuel) and/or too far advanced.
You can check the fuel pressure by buying a fuel pressure test kit at any local auto parts store. attach it to the Schrader valve on your fuel line and see if it is in spec. (not sure of the spec on BMW's, I know my car needs at least 55psi to run properly)
Old 01-04-2005, 03:24 PM   #10 (permalink)
TMac325is's Avatar
no, the rev limiter is computerized, unless the previous mysteriously reprogrammed the computer chip its not possible, check into the fuel pressure problems
Old 01-04-2005, 05:03 PM   #11 (permalink)
im going to check the fuel pressure and see if its too far advanced today... it just seems to choke at about 5000rpm and the "check engine" light comes on for a second . Once in a while tho it shifts near the red line shown on the tach 6250rpm (estimate)
.:.HTP.:.
Old 01-04-2005, 07:56 PM   #12 (permalink)
jze325i's Avatar
jze325i is an unknown quantity at this point
MORE THAN LIKELY IS YOUR FUEL PRESSURE REGULATOR, FAIRLY INEXPENSIVE.. EASY FIX.. I AM SURE THAT IT HAS NOTHING TO DO WITH YOUR REV LIMITER THOUGH
jze325i is offline   Reply With Quote
Old 01-04-2005, 09:22 PM   #13 (permalink)
alright thanks
ill be checking the pressure tomorrow... they had to order a test kit (small stupid store)
.:.HTP.:.
Old 01-04-2005, 09:59 PM   #14 (permalink)
jze325i's Avatar
GOOD LUCK WITH THAT!
Old 01-06-2005, 11:39 AM   #15 (permalink)
brodee is an unknown quantity at this point
[snapback]264166[/snapback]
There is no schraeder valve on the fuel line of an m20. You can put a t-fitting in the line and use a gauge if you want though.
I have a brand new factory 3.0 bar fuel regulator for sale that I got at the dealer. I ran it for a week before my new adjustable FPR came in.
Let me know if you need one.
<img src='http://www.tmdnet.com/bmw/bmwsig4.jpg' border='0' alt='user posted image' />
brodee is offline   Reply With Quote
What Is My Cars Problem!!!????? spfdfanatic 3-Series (E36) 7 01-05-2005 09:39 PM
