powersteering leak - BMW Forum - BimmerWerkz.com
Old 08-08-2008, 02:46 PM   #1 (permalink)
momty is on a distinguished road
Angry powersteering leak
I have a 1992 318i convertable Mtecnic with only 56k and fluid coming out of the drivers side steering rack boot. Should I attempt replacing it myself? Has anyone had luck doing it themselves and has any tips?:
momty is offline   Reply With Quote
Old 08-08-2008, 03:17 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
you're in luck!... the rack and pinion is out in the open and a relatively easy job to do.
trying to replace just the end seal is a pretty much a thing of the past(don't even know if you can find just the end seal anymore...), and it will be easier for you to replace the whole rack and pinion assembly-doesn't hv to be brand new; remanufactured ones work just as well
Old 08-08-2008, 03:29 PM   #3 (permalink)
Hey thanks alot for your reply. Any place you prefer to get remaned parts?
Old 08-08-2008, 03:46 PM   #4 (permalink)
search the 5 series forum... i remember a discussion about a GOOD and cheap source for remanufactured rack-and-pinion there.
or PM jpmoorman... he would know ;-)
*TIP: if u are doing the work yourself, you'll need to go for alignment after you change the steering gear. otherwise, ur tires will not be "on track"
powersteering retro fitted gregnation 3-Series (E21, E30) 4 04-30-2006 07:10 PM
engine noise....maybe powersteering????? someguy 3-Series (E36) 3 09-26-2005 09:12 AM
Fuel Leak akhtar 5-Series (E12,E28, E34, E39, E60) 0 02-28-2005 07:19 AM
93 740i Powersteering Fluid??? robob69 1,6,7,8 - Series and Mini Cooper 4 12-23-2004 07:09 PM
Leak! Can Someone Help fredo 328 3-Series (E36) 4 12-08-2004 10:17 AM
