Power Window Trouble... - BMW Forum - BimmerWerkz.com
Old 08-30-2004, 04:05 PM   #1 (permalink)
HoFF is an unknown quantity at this point
Send a message via AIM to HoFF
Okay. Today I went into my car and tried to roll up all the windows. The only problem was that the passenger front window would not roll up at all. Over the past few days that I have rolled that window up, I have noticed that it was going a little slower than all the rest of the windows. Now I can't roll it up at all. Does anyone know what to do to fix this problem? Possibly get a new motor or it lost its juice or what?
HoFF is offline   Reply With Quote
Old 08-30-2004, 07:31 PM   #2 (permalink)
DANM is an unknown quantity at this point
change your switches .these switches are prone to contact burning(within the switch) dirty contacts produce higher resistance and lower voltage to your window motor and slower than normal operation. eventually failing completely.
DANM is offline   Reply With Quote
Old 08-30-2004, 10:13 PM   #3 (permalink)
ye12 is an unknown quantity at this point
I doubt if it is your window motor. The BMW parts guy told me that they rarely replace motors. Check your window alignment, because it may be binding and stalling your motor. To do this, roll your window up and leave a small gap open. Check that the top of window glass is parallel to the frame.
ye12 is offline   Reply With Quote
Old 08-30-2004, 11:51 PM   #4 (permalink)
I would try that but I can't roll up my windows at all. I try pushing up on the button then try to pull the window up, but it doesn't come.
Old 08-30-2004, 11:56 PM   #5 (permalink)
You won't believe it, but I had that problem too. But in my case it just starts working again
Old 08-31-2004, 12:44 AM   #6 (permalink)
Does the one that got stuck have the same power going up as all the other windows?
Old 08-31-2004, 01:08 AM   #7 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
voltage check!!!!!
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 08-31-2004, 03:09 PM   #8 (permalink)
Originally posted by HoFF+Aug 31 2004, 12:31 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (HoFF @ Aug 31 2004, 12:31 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-ye12@Aug 30 2004, 10:53 PM
I would try that but I can't roll up my windows at all. I try pushing up on the button then try to pull the window up, but it doesn't come. [/b][/quote]
I had a similar problem with my left rear window stuck open. I took off the door panel (easy to do) and disconnected the window motor. I then wired up the window motor directly from the battery using a jumper cable and a short piece of wire to connect to the motor connector. Just reverse the connection to change the direction of the widow operation.
Be careful because you don't have a fuse to blow if something shorts out. I took a chance, but I first just tapped the wires together to see if the window would move.
Old 09-01-2004, 04:58 PM   #9 (permalink)
Well I just took out the switch I have now and cleaned it up and now it works great. I can finally roll my window back up. Thanks for the help guys. B)
Window Trouble Sporty540 5-Series (E12,E28, E34, E39, E60) 4 01-10-2005 11:49 PM
Power Window Problem 123NotIt 3-Series (E36) 4 12-02-2004 02:02 PM
Power Window And Door Lock Problem...96 750il moabxj01 1,6,7,8 - Series and Mini Cooper 1 11-16-2004 03:30 PM
Power window fun! kestrel325is 3-Series (E36) 7 07-17-2004 09:56 PM
