Power steering work - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 06-21-2013, 12:33 AM Thread Starter
m20enginebuilder is on a distinguished road
Power steering work
So Im planning on within a few days ripping the entire power steering system out of my 1990 E30 and completely overhauling it, because before I owned it some idiot ran the wrong fluid in it, and it destroyed the whole system. It used to half-ass work and make tons of noise, but now it dont work entirely, and the fluid is blacker than the blackest black times infinity, due to all the seals inside the rack being destroyed by the wrong fluid. How easy is it to remove the steering rack and pinion assembly? I looked up how to do it on Alldata, but the problem is it was very vague on how to go about doing it. I KNOW how to remove the power steering pump assembly, because the guide for that on alldata was actually informative, and it showed how to do it, unlike with the steering rack. So if someone can give me some detailed instructions on how to go about removing the steering rack, Id be very appreciative.
m20enginebuilder is offline
post #2 of 8 (permalink) Old 06-22-2013, 07:16 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
To remove the rack, it should just be two main bolts that holt it in once the tie rods are disconnected. At least it is on the E36.
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #3 of 8 (permalink) Old 06-22-2013, 10:09 PM Thread Starter
I took a good long look under the hood today, and yes it looks like theres the 2 support brackets- 1 on the driver side, and one on the passenger side. Then the lower column U joint that goes into the input shaft for the pinion gear. So it looks as simple as disconnect the 2 tie rod ends, disconnect the lower column from the input shaft, remove the 2 support brackets and their bolts, and out it comes.
post #4 of 8 (permalink) Old 06-28-2013, 06:40 PM Thread Starter
Also I forgot to ask, but how exactly would I go about putting in a power steering fluid cooler? Im gonna be doing alot of canyon carving, and I kinda want to make sure the fluid dosnt get too hot. And seeing as Im gonna have the entire p/s system tore out and apart, I figured, why not put a cooler into the loop?
post #5 of 8 (permalink) Old 07-01-2013, 01:41 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
Well what I have seen for the E36 is an oversized power steering resevoir made of aluminum with cooling fins for increased fluid capacity and additional cooling. It was pretty costly at $400 though.
The return line from the rack is the "cooler" really. You could try to see if their are return lines that are longer for increased cooling.
post #6 of 8 (permalink) Old 07-01-2013, 11:04 PM Thread Starter
I was thinking more along the lines of an air to oil cooler, like a transmission cooler. How would I install that into the loop?
post #7 of 8 (permalink) Old 07-06-2013, 07:40 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 1 Post(s)
Well you could cut the PS line and then solder/weld in new piping and run it to a small transmission cooler. You wouldnt need anything huge, and you wouldnt want to block the transmission cooler (if you have one). Basically just a cut, splice, and mount job.
post #8 of 8 (permalink) Old 07-06-2013, 09:46 PM Thread Starter
Sounds easy. Also no trans cooler. It has the Getrag 260 5 speed.
E36 steering wheel swap HORN will not work? fast2002 3-Series (E36) 1 05-10-2012 08:43 PM
Power Steering Noise When Turning Steering Wheel musclecarenvy 3-Series (E46, E90) 4 04-09-2010 07:06 PM
525i Steering Wheel Adjustor doesn't work balbs 5-Series (E12,E28, E34, E39, E60) 4 02-22-2010 01:37 AM
Power Windows-sunroof Don't Work nicolab 3-Series (E36) 2 09-26-2004 12:14 PM
Steering wheel controls don't work...How do I get 2001BMW330iRob 3-Series (E46, E90) 1 08-19-2004 03:50 PM
