Hey all, I was doing some fluid inspections the other day and noticed that the Power Steering fluid looks like it is contaminated with water. I just got a new head gasket, thermostat, etc... so I may as well go all the way! Any suggestions on best methods/techniques to flush/fill the power steering system?
Thx!
Josh W.
__________________ Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
Disconnect the two tubes from the rack, and let her go!! I'm not sure if that will drain the reservoir as well, though. If not, you can just turn the car on, and that should shoot the fluid out pretty good. sounds like fun... Hmmm....
__________________ '86 325es (TURTL3): PJ peetsa hawler
'04 x3 3.0i: Wife's Bimmer (manual, woot!) My BMW Blog
okay, one more quick question... and it isn't as stupid as it sounds!
Would I use Power Steering Fluid or Brake Fluid?
I had a car (wish I could remember which one it is) that took Brake Fluid for power steering, so I don't wanna phuq this up!
Thanks!
Josh W.
Dissconnect the return hose to the resivour and run it into a bucket (you may need to attach a longer hose but dont worry its not really high pressure or anything)
An assistant makes the job a lot easier - you have some fluid ready and start the car, then procede to turn the wheel lock-to-lock several times, while the assistant dumps fluid into the resivour - keeping it full.
When the fluid coming from your return hose looks clean, shut the engine off and stop turning the wheel.
Re attach the return line and start the car again, and turn the wheel lock to lock again while adding fluid to top off - the system is self-bleeding. Easy as pie! Steering should have a crisper feel now.
As far as your fluid, I don't know. I know E36s use ATF in there but many cars use brake fluid. Check the manual or im sure someone in the forum drivin an e30 knows. Just don't get any fluid on the paint - it will turn a real dull grey color. Ask me how I know.
LOL! No offense Spooled, and you are right, I didn't show you any love. As a result, I am willing to offer you a prize as an appology... You have your choice of either a used but functional Coil, or a used but non-functional driving light bulb! DAMN am I generous!
werd
Josh W.
^^ oh. Don't I feel like the fuckin' asshole...
Guess it would help if I actually read the Bentley Manual instead of just assuming that power steering fluid goes in the power steering reservoir. ghead
I'm so sorry for the misinformation.
p.s. Dude, I'm so freakin' embarassed. I apologize again. (I have to go apologize to my car that I've been feeding Power Steering Fluid to for 2 years):
It is done, but it looks like I didn't crank it back and forth enough to fully flush it out. Once I started it up (valve adjustment done so no typewriter under hood!!!) I checked the fluid, and it had clouded back up. I will flush it again next weekend and this time, I will do it RIGHT!
Thanks again for everyone's input!
Josh W.
HOLY CRAP....is that what that "ATF ONLY" label is on top of the res??>!?!?>!?>!! DUH... I just changed my rack, and of course put power steering fluid in it....looks like I've got some more flushing to do... Not to worry flipper foot, I had some air in mine directly after filling and purging....it cleared up after it sat for awhile and all is well (except for the use of power steering fluid I gues.......I get to do it again soon..... ATF...hmmmmm....wierd.
Josh W.
Ah yes, the engine needs to be running to pump the old gunk out while you turn the wheel. Assistant is the key. Good luck!
