Power Steering - PS fluid or ATF - BMW Forum - BimmerWerkz.com
Old 06-15-2004, 11:39 AM   #1 (permalink)
Jmiller911 is an unknown quantity at this point
I'm having problems with my Power steering sytem leaking. It first started when my BMW dealer did some work on my car and left a line loose. I put int ATF fluid thinking that was the same as PS fluid. I changed out the ATF fluid and put in PS fluid. Now the leak is greater (mostly around the steering rack). Which fluid should I use? Would PS fluid make the leak worse? Help!!
Jim
Jmiller911 is offline   Reply With Quote
Old 06-15-2004, 01:21 PM   #2 (permalink)
get your steering rack replaced if you want to stop the leak, i doubt the leak will get any better no matter what you put in.
Old 06-15-2004, 09:16 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
ATF is what goes in your E30 power steering system, says so right on the cap.
My M50 Powered E30 Page
Power Steering Fluid jones112b 3-Series (E36) 2 08-22-2005 07:53 AM
318is Power Steering Fluid taylor 3-Series (E36) 0 06-28-2005 07:42 AM
Power steering fluid TMac325is 3-Series (E36) 10 05-28-2004 05:20 PM
Importance of Power Steering Fluid? jlb318 3-Series (E36) 5 05-20-2004 08:42 AM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
