Power Steering Fluid - BMW Forum - BimmerWerkz.com
Old 10-01-2006, 01:23 PM   #1 (permalink)
jheabs is on a distinguished road
I have a 1988 BMW 325iS. Can someone tell me where to find the power steering fluid and how to replace it? Thanks
jheabs is offline   Reply With Quote
Old 10-01-2006, 01:30 PM   #2 (permalink)
87325es is on a distinguished road
it should be in a black canister. Just unscrew the clamp and lossen the clamp which is connected to the canister. (make sure you clog the hole of the container so you dont make a mess).
87325es is offline   Reply With Quote
Old 10-01-2006, 01:53 PM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
It will be a black or brown canister that is attached to the drivers side strut tower. The best way to change the fluid is to undo the hose on the pump and let it drain out. Then refill with regular ATF trans fluild. DO NOT PUT POWER STEERING FLUILD BACK IN IT. The power steering system in the E30 was designed to work with ATF, using regular power steering fluid can mess up the pump and seals in the system.
My M50 Powered E30 Page
Old 10-01-2006, 03:21 PM   #4 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
^^ what he said. ATF only.
My BMW Blog
Old 10-01-2006, 04:36 PM   #5 (permalink)
Is Dexron III the ATF fluid i need to use?
Old 10-02-2006, 01:09 AM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Yes.
power steering fluid flush WarNox 3-Series (E36) 2 08-10-2006 03:10 AM
power steering fluid WarNox 3-Series (E36) 0 07-20-2006 04:00 AM
$8.00 Power Steering Fluid Change acoustic 3-Series (E36) 0 05-18-2006 01:11 PM
Power Steering - PS fluid or ATF Jmiller911 3-Series (E21, E30) 2 06-15-2004 09:16 PM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
