Power Steering Fluid - BMW Forum - BimmerWerkz.com
Old 01-17-2005, 09:58 AM   #1 (permalink)
expectthebest is an unknown quantity at this point
Recently I had a leaky steering rack in my 91 318is and had it replaced by a local mechanic. He put regular power steering fluid in instead of the required ATF fluid. Will this cause damage? Can I siphon out the reservoir and replace it with ATF without problems? Thanks!!
expectthebest is offline   Reply With Quote
Old 01-17-2005, 03:48 PM   #2 (permalink)
detour54 is an unknown quantity at this point
Send a message via AIM to detour54
[snapback]273198[/snapback]
Yes, it could eventually present a problem.
I suggest you flush your power steering system, instead of siphoning.
<a href='http://www.e30tech.com/forum/viewtopic.php?t=8854' target='_blank'><img src='http://www.e30tech.com/pictures/e30/sig25.jpg' border='0' alt='user posted image' /></a>
detour54 is offline   Reply With Quote
Old 01-17-2005, 04:00 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Good thing to do.. pull one of the connections under the resevior... drain it... then put it back.. and put water in it... turn car on.. move wheel to the extrem left then all the way right... then drain... put in ATF fluid... and move wheel to left and right.. make sure level is correct... and your done..
Peace,
Les
1997 E36 M3 1990 E30 325i
Old 01-17-2005, 06:05 PM   #4 (permalink)
Peace,
Les
[snapback]273503[/snapback]
Or you could disconnect the return line on the pump. Make sure you put a bucket underneath. Turn the car on and have someone turn your steering wheel while you fill the reservoir. Keep an eye on the bucket, and when you see the same color that your adding coming out, stop.
Power Steering Fluid jones112b 3-Series (E36) 2 08-22-2005 07:53 AM
Power Steering - PS fluid or ATF Jmiller911 3-Series (E21, E30) 2 06-15-2004 09:16 PM
Power steering fluid TMac325is 3-Series (E36) 10 05-28-2004 05:20 PM
Importance of Power Steering Fluid? jlb318 3-Series (E36) 5 05-20-2004 08:42 AM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
