Pertronix electronic ignition COIL - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 09-04-2004, 07:31 PM Thread Starter
shield is an unknown quantity at this point
Has anyone replaced their stock ignition coil with the Pertronix electronic ignition Coil?
Is this thing any good?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...bayphotohosting
shield is offline
post #2 of 10 (permalink) Old 09-05-2004, 04:28 AM
Crazy Fabricatin' Admin
gotKRAUT's Avatar
gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute gotKRAUT has a reputation beyond repute
that looks like the one i had on my 67 VW that burned up...stick to big brands...
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #3 of 10 (permalink) Old 09-05-2004, 03:33 PM
wcleafs
Guest
Posts: n/a
Quoted: Post(s)
I went with a MSD Coil in my 83 320i, approximently 10 Kv more spark over stock coil.
improved mileage and I think gave it a little boost in performance.
post #4 of 10 (permalink) Old 09-05-2004, 07:54 PM
whunter's Avatar
whunter is an unknown quantity at this point
Hello shield
I have installed the Pertronix systems on Rolls-Royce, Bentley, Porsche, Fiat, VW and BMW.
The system and parts have worked well.
The question is; why are you installing it?
It will give a hotter spark, if the spark plugs, wires, rotor and cap are good, if they are marginal or bad, it will finish off the sub standard parts in record time.
If you are looking for more power and better performance:
#1. Full tune-up = new spark plugs, wires, rotor and cap.
#2. Clean the throttle body and plate.
#3. Replace the intake manifold injector seal rings.
#4. Check injector spray pattern.
#5. Replace the OEM air filter every 3000 miles, regardless of how it looks.
#6. Check for vacuum leaks and repair or replace as needed.
#7. Check for brake caliper drag, rebuild or replace as needed.
#8. Check all wheel bearings for slop or rough spots in rotation, and adjust or replace as needed
#9. Check tires for shifted belts, uneven wear, bent rims and correct air pressure, further diagnosis may be needed.
#10. Check engine and transmission mounts for cracking, oil saturation = marshmallow feel or total separation, replace as needed.
#11. Do a compression test and cylinder leak down test, post the results.
#12. Check fuel pump pressure.
#13. Use only synthetic oil in the engine.
I will stop here; the list of things that can have an effect on performance is huge
whunter
ASE Master Mechanic
AUTOKUNST
754 Orchard Lake Road
Pontiac, MI. 48341
Phone# 248-334-3120
Fax#248-334-0435
whunter is offline
post #5 of 10 (permalink) Old 09-05-2004, 11:32 PM Thread Starter
I'm slowly getting there pending my budget.
within the last two weeks I've replaced.
plugs
plug wires
distributer cap and rotor
shocks and struts (including mounts)
new performance tires
air filter
switched to Mobil 1 synthetic
fuel filter
tranny fluid
differencial fluid
slowly working my way to the others
thanks
shield is offline
post #6 of 10 (permalink) Old 09-06-2004, 02:26 PM
whunter's Avatar
Post
Do yourself a favor.
#2. Clean the throttle body and plate. = a can of throttle body cleaner and brush.
#6. Check for vacuum leaks and repair or replace as needed. = a water spray bottle to spray intake and hoses, listen for any change of RPM, do small areas.
These two are critical for any BMW and cheap.
whunter
ASE Master Mechanic
AUTOKUNST
Pontiac, MI. 48341
Phone# 248-334-3120
Fax#248-334-0435
whunter is offline
post #7 of 10 (permalink) Old 09-07-2004, 02:20 AM Thread Starter
Those will be my project for tomorrow.
shield is offline
post #8 of 10 (permalink) Old 09-07-2004, 02:27 AM
gotKRAUT's Avatar
i have heard HORRIBLE things about using water from numerous BMW and other German car mechanics...my advice is use chlorine free brake cleaner and the car will idle up...but avoid sprayin on painted surfaces :P
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
post #9 of 10 (permalink) Old 09-07-2004, 07:24 PM Thread Starter
I just cleaned the Throttle body/plate, and the PCV hose. What a mess. It was filthy in there and I couldn't believe the buildup in the PCV hose.
Got a bottle of injector cleaner, used up a lot of clean rags and sacrificed my fiance's toothbrush (got her a new one before she kicked my ass).
I'll get some brake cleaner and do the vacuum leak test tomorrow.
Maybe it's the placebo effect, but I think she idles smoother already .
shield is offline
post #10 of 10 (permalink) Old 09-07-2004, 07:37 PM
gotKRAUT's Avatar
niceeeee.. ..be sure to use non clorinated and dont get it on anything painted...but it works great
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast
gotKRAUT is offline
Ignition Coil Problem Ethylene Oxide 3-Series (E46, E90) 1 08-16-2004 07:04 PM
Bad Ignition Coil or ECM? 93 318i kylejsutin 3-Series (E36) 4 08-09-2004 10:15 PM
Electronic Ignition Protection Skipjacks M-Series (M1, M3, M5, M6) 4 07-31-2004 12:29 PM
90 525i - bad ignition coil? thebaldguy 5-Series (E12,E28, E34, E39, E60) 1 04-26-2004 04:38 PM
