| You need the 215mm, or you can get a 228mm flywheel from a 2002tii or get a lightned and balanced unit from TEP, it will provide more grabbing surface area and is a direct bolt on, but if your motor is stock dont waste your money, its not worth it for your stock application, the flywheels will run you at TEP about $309 and a lightned alum unit. like mine is about $500
__________________ <img src='http://e21.tricord.cjb.net/members/cjpix/bim1_050204.jpg' border='0' alt='user posted image' /> |
