overheating at idle - BMW Forum - BimmerWerkz.com
Old 07-10-2007, 06:11 PM   #1 (permalink)
mike10 is on a distinguished road
overheating at idle
91 318is
The car has 240k and I just replaced the cracked radiator and new thermostat. The fan clutch is fine and the high heat hose is fine. It doesn't leak any coolant and none of my hoses are cracked or worn. It keeps a decent temperature while the rpms are kicked up but at lower rpms or at idle, it immediately begins to overheat. I'm thinking water pump but has anyone heard of those impellars getting worn to the point where they slip like that. Is there some kind of in-line pressure release valve orsomething i should be looking for? Don't wanna replace the waterpump if I don't have to.
Thanks.
Mike
mike10 is offline   Reply With Quote
Old 07-10-2007, 07:04 PM   #2 (permalink)
Car: Opening soon:
Make sure you bleed it. Also make sure you installed the thermostat the right way with the spring inside the motor.
Old 07-13-2007, 06:19 PM   #3 (permalink)
when you say to "bleed it," do you mean to let the car run for a while with the resevoir cap off to get any air out of the system?
Old 07-13-2007, 10:48 PM   #4 (permalink)
Car: Opening soon:
No, open the bleed screw. It should be next to the radiator cap if you have the black plastic tank.
My camry keeps overheating when im at idle, but... SpeedInfusion Other Rides 15 06-01-2007 01:52 AM
Overheating At Idle BImmerN2B 3-Series (E36) 31 09-06-2005 12:39 PM
Overheating At Idle In Traffic wcre34 3-Series (E36) 7 08-15-2005 09:58 AM
