Ok Its Starting To Overheat - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 01-20-2005, 04:36 PM Thread Starter
W00T
Numark318i's Avatar
Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute
alright so my coolant is leaking somewhere or evaporating. I fill it up every three weeks(and by fill up i mean put more in it.) and if i forget it starts to overheat. SO i took it to my mechanic..he said nothings wrong with it, he pressure tested it. HE also change the fluid. I changed the radiator car and the thermostat...I cant firgure out why the hell its doing this.
Numark318i is offline
post #2 of 14 (permalink) Old 01-20-2005, 05:14 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
Did you bleed the system after changing the thermostat ?
Torque is offline
post #3 of 14 (permalink) Old 01-20-2005, 08:59 PM Thread Starter
W00T
Numark318i's Avatar
[snapback]275731[/snapback]
yea why. We just emptied it as much as we could and filled it back up, no flush though.
post #4 of 14 (permalink) Old 01-21-2005, 01:44 AM
Kowalski's Avatar
Originally posted by Numark318i+Jan 20 2005, 06:59 PM--><div class='quotetop'>QUOTE(Numark318i @ Jan 20 2005, 06:59 PM)</div><div class='quotemain'><!--QuoteBegin-Torque@Jan 20 2005, 04:14 PM
[snapback]275815[/snapback]
[/b][/quote]
just currious but what was your compression when you tested it? or do you mean presure test the radioator, you could be burning coolant, or leaking out of a gasket somwhere. other then that it shouldn't be evaportaing, unless you radiator is leaking.
264* roatation and 388 lift
Kowalski is offline
post #5 of 14 (permalink) Old 01-21-2005, 01:54 AM Thread Starter
W00T
Numark318i's Avatar
Originally posted by Kowalski+Jan 21 2005, 12:44 AM--><div class='quotetop'>QUOTE(Kowalski @ Jan 21 2005, 12:44 AM)</div><div class='quotemain'>
[snapback]275955[/snapback]
[/b][/quote]
well idk i didnt pressure test it.
Ill talk to my mechanic and my dad...maybe a gasket somewhere...it is 14 years old.
post #6 of 14 (permalink) Old 01-23-2005, 11:08 PM
sniady is an unknown quantity at this point
i found that the hose from the expansion tank to the the radiator is negelected when replacing other coolant hoses. Inspect it.
sniady is offline
post #7 of 14 (permalink) Old 01-24-2005, 01:20 AM
RealBMW 02's Avatar
RealBMW 02 is an unknown quantity at this point
Send a message via AIM to RealBMW 02
its not very uncommon to need to add coolant every three weeks on an old car.
I check my coolant every two days before i start it up, along with my oil. Just a good habbit to get into.
If you keep the coolant level full does it still overheat? If not there really isn't anything to worry about. Just keep checking all the time to make sure it is full. Good luck
Adam
<img src='http://files.unitedbimmer.com/ub.c/RealBmw%2002/Sig_ver2.jpg' border='0' alt='user posted image' />
1970 - 2002
Proud Memeber: 30+ year old car club
RealBMW 02 is offline
post #8 of 14 (permalink) Old 01-24-2005, 11:25 PM
e30 dude is an unknown quantity at this point
maybe your aux fan is not working. when the engine heats up, pressure builds up and the rad cap opens to let coolant out. maybe that's why you're losing coolant. also, maybe you replaced your rad cap with a lower pressure rad cap, and so it opens a lot sooner. does it heat up only when you're stuck in traffick?
e30 dude is offline
post #9 of 14 (permalink) Old 01-25-2005, 04:31 PM Thread Starter
W00T
Numark318i's Avatar
[snapback]278587[/snapback]
well i got a new radiator cap...that didnt work.
I will try to fill it up every third day..i usualluy did it every two weeks.
Also my friend commented my fan is moving very slow.
post #10 of 14 (permalink) Old 01-25-2005, 05:06 PM
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of spiff325is has much to be proud of
Send a message via AIM to spiff325is
just get a new car..haha.
but overheating is usually due to coolant, or crapz radiatorz.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline
post #11 of 14 (permalink) Old 01-25-2005, 10:53 PM
RealBMW 02's Avatar
do you have a overflow catch can? if so then you shouldn't be loosing coolant at all. the coolant might overflow from the cap, but then when it cools off it should come back into the radiator.
If you don't have a catch can then when the coolant boils over on hot days it will be lost and refill will be neccessary.
Also, you could have a broken fan clutch which is allowing the fan to spin at very low speeds (like your friend said). But this will really only affect you if you do a lot of stop and go driving or sitting in traffic. Once you start moving the air flow through the radiator will illiminate the need for a fan.
Adam
1970 - 2002
post #12 of 14 (permalink) Old 01-25-2005, 11:26 PM
Abdul is an unknown quantity at this point
I had an overheating problem on mine, I found it was related to air not being bled from the system. The bleed screw usually takes care of it, but in my case I had to loosen up the temperature sender on the top of the engine to "burp" the last little bit of air from the system.
Abdul is offline
post #13 of 14 (permalink) Old 01-27-2005, 01:16 AM Thread Starter
W00T
Numark318i's Avatar
[snapback]279399[/snapback]
well no air...i made sure of that.
Spiff...i dont need ur shit...my cars great cept for the whole overheating thing
Yea Ima add fluid every few days...if i do that it wont overheat. THe fluid is cominfg out somewhere..not really a leak though.
haha..i convinced this girl..after drving my car, to buy a 1995 325is..lol.
and guess who can drive it..hopefully...lol
post #14 of 14 (permalink) Old 01-27-2005, 02:13 AM
Torquester325's Avatar
Torquester325 is an unknown quantity at this point
Send a message via MSN to Torquester325
yah, i would say that your fan clutch is shot
its pretty easy to change
just check the bentley and see what they say. they also have a way to diagnose if it is shot.
<img src='http://img27.exs.cx/img27/3388/torquester325sig27zc.png' border='0' alt='user posted image' />
Torquester325 is offline
BMW 318i 92Model E36 Starting Problems deanbelich 3-Series (E36) 7 09-21-2005 12:41 PM
Starting Problems BMWDriver86 3-Series (E21, E30) 15 02-09-2005 05:28 PM
Cold Starting _1634_ 3-Series (E36) 2 09-07-2004 05:03 PM
318 not starting ProffK 3-Series (E46, E90) 3 07-07-2004 11:31 PM
