Oil temp and pressure sending unit mounting - BMW Forum - BimmerWerkz.com
post #1 of 1 (permalink) Old 04-12-2014, 12:06 AM Thread Starter
m20enginebuilder is on a distinguished road
I obtained a Cessna instrument panel(has cyl head temp, oil temp, pressure, etc) and I need to know where to mount the sending units. The oil pressure gage is electric, 12 volts(opposed to 24, like some aviation parts are), and I need to know where to mount a pressure sending unit for this instrument. Now the oil TEMP on the other hand is MECHANICAL. Which means it has this 6 or 8 foot long metal tube with a bulb on the end of it, with a heat sensitive expanding fluid in it, probly mercury. I also need to know where I can mount this sending unit(bulb thingy). Theres a slight problem- its nut is loosely fitted, so it rotates without twisting the metal tube. The bulb has a copper squish washer on it, and a flange that the nut cinches up against. So whether i have to tap a specific hole in the oil pan for it, id have to make a flange for the squish washer so it dont leak oil. Id just like some input so I can figure out how to mount this nightmare of a panel, because 1, Id like to have oil pres and temp, and 2, it looks real cool in the bare spot on the centre console underneath the stereo rack. Im not too worried about that metal tube for the temp instrument, as it is very long. I just need to be careful with it so I dont break it, and have the fluid inside leak, ESPECIALLY if it does happen to be mercury. Any input would be much appreciated, thanks! I wanna do work on my E30, seeing as it is warming up here, it was very nice today, so i started removing some of the AC system, because im doing an AC deleat on it for weight reduction-the compressor was HEAVY, had to have weighed at least 13 lbs.
m20enginebuilder is offline
1988 325Ic temp sending unit problem jjuken 3-Series (E21, E30) 8 08-12-2012 02:23 AM
1992 318is Oil Pressure Sending Unit kopernicus 3-Series (E36) 0 01-02-2011 01:53 PM
318is E36 Oil Sending Unit kopernicus New Members Check In 0 01-02-2011 01:46 PM
Oil Pressure And Oil Temp Guage Opinion jmo69 3-Series (E36) 2 01-10-2010 10:54 PM
Coolant Temp Sending Unit 325eXTATIC 3-Series (E21, E30) 9 09-20-2005 11:37 AM
