| Oil Pressure Light So i just recently replaced my head gasket. And i was looking through my bentleys and realized that i neither had to disconnect or reconnect the oil light sensor that is located next to the distributor on the end of the head. (I have an 85 318i). So i ran right out and popped the hood and see that at some point it appears someone crossed the wires together and tucked them under the battery plate. I dont know why they would have done this. But i know the shop put a new sender in the head when they rebuilt it. How should this be set up so i can connect it? I can post a pic if its not clear. Thanks |
