| Oil Pan Gasket Replacement/Brake Job Problems Ok I finished my oil pan gasket job. I did rotors and brakes while I was at it. Here's what I've got
(1) car won't start [I already solved this one - bad ground]
(2) Oil Pressure Light on the overhead panel
(3) Anti-Lock light is on until gas pedal is pressed
(4) Battery light is on until pedal is pressed
(5) Brake Fluid light is on
I filled the car with 4.25 quarts, oil is on the dipstick, nothing is leaking from the engine
Anti-lock/Battery light - I have no clue
Brake Fluid - I have no clue the reservoir is full
Ideas appreciated as always.
Stephen |
