Oil Or Grease On Top Of The Engine? - BMW Forum - BimmerWerkz.com
Old 02-24-2005, 11:13 PM   #1 (permalink)
tyro2001's Avatar
tyro2001 is an unknown quantity at this point
hi im thinking about buyinh a car but there is one thing that looks kinda fishy. on top of the vavle cover there is some kind of oil or grease i cant see where it came from. i looked for leaks i didnt see any thing. could it be seriouse or just some fool spilled it on the engine?
thanks
PS: if you any test that i should do please tell me i am going to look at it again towmorrow, its a 1989 325i
tyro2001 is offline   Reply With Quote
Old 02-25-2005, 12:23 AM   #2 (permalink)
Kowalski's Avatar
thanks
[snapback]298933[/snapback]
compresion test, also do a vacume test see if shes leaking anywhere. and the oil on top is most likley from spilling when pouring which shows a careless owner. be warned!!!! and every other standard test, best to get a mechanical inspection by a shop or somthing.
264* roatation and 388 lift
Old 02-25-2005, 07:38 AM   #3 (permalink)
CiscoKid's Avatar
it might be a valve cover gasket leak... they are very easy to replace, and cost less than $50. I would reccomend getting a compression and vacuum test done to make sure the engine is in good health
Old 02-25-2005, 08:43 AM   #4 (permalink)
tyro2001's Avatar
how is a compressing/vacum test done?
Old 02-25-2005, 09:41 AM   #5 (permalink)
just take it to a BMW shop and ask for a used car inspection, usually they charge half an hour labor, if the owner wont let you then you dont want the car. The vacuum and compression should be fine if it runs good and doesnt have any loss of power
Old 02-25-2005, 10:31 AM   #6 (permalink)
tyro2001's Avatar
thanks
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 02:40 PM
