| are you sure it isnt leaking? it could, not drip oil on the ground but still have a leak. i would get your seals checked, it could be leaking oil on the timing belt and you wouldnt even notice it. also there is a valve on the oil cooler thats known to leak on earlier M20B25's, but that you could probably notice. |
