Which oil is best for e30 engine ??? - BMW Forum - BimmerWerkz.com
Old 10-30-2011, 07:07 AM   #1 (permalink)
dreamriser's Avatar
Car: 1989 / BMW / 325i
dreamriser is on a distinguished road
Hi all,
I'm about to make an oil change in my 1989 325i ,and I wanted to know which oil you guys recommend I use in my engine.
Thanks in advance.
dreamriser is offline   Reply With Quote
Old 11-09-2011, 04:41 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
More than anything, i'd recommend using whatever you've been using. You'll find a million opinions on synthetic vs organic, or heavy weights in the winter, lighter in the summer, yada yada. At the end of the day, being consistent is the best thing you can do. Changing brands/weights/etc. from oil change to oil change is worse than using one oil versus the another. Most BMW techs will vote Castrol GTX 20-50, but I'm a mobil 1 guy and use 0-40 based on higher mileage (which using a light weight oil decreases resistance across internal components).
Old 11-15-2011, 01:46 AM   #3 (permalink)
Car: 89 325i Cabrio Turbo.
Dublbass_monster is on a distinguished road
My buddy works at Moritz Mini/BMW/Cadillac and says that packaged BMW motor oil is made by CASTROL, so buying castrol full synthetic 5-30 is great for all seasons here in hot and cold a$$ state of texas, should be great for anywhere else, unless severe cold or elevation ail you. Hope you find peace with the amber goodness. I'm running royal purple 10w-30 full synthetic motor oil, royal purple synchromax manual gear oil, and 75w-90 full synthetic royal purple gear oil. and everything is chipper and fresh feeling again. What I imagine the vehicle should have felt like NEW. Good luck.
Dublbass_monster is offline   Reply With Quote
Old 11-30-2011, 01:44 PM   #4 (permalink)
dreamriser's Avatar
Thanks
Thanks for the info guys,much appreciated.
Old 12-01-2011, 08:04 PM   #5 (permalink)
North's Avatar
Car: 1990 325is
North is on a distinguished road
The manual recommends 10w40 for colder climates/winter and 20w50 for summer. If you go lower than this, I'd be scared of damaging my engine.
North is offline   Reply With Quote
Old 12-02-2011, 11:01 AM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Some good advice there buddy... I would go for the Semi Synthetic versions of the above ;-)
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 01-15-2012, 06:00 PM   #7 (permalink)
Car: 1987 BMW 325 2 door CHOCO-BROWN
deafdog is on a distinguished road
I live in southeast US and I use 15-40 conventional diesel motor oil, it seems to run better for some reason.
deafdog is offline   Reply With Quote
Old 03-22-2012, 04:43 AM   #8 (permalink)
stamar is on a distinguished road
20-50 in most of america. 10-40 in wisconsin south dakota type places.
15-40 diesel oil is good for places with a normal winter.
15 50 full synthetic
that first number is indeed the coldest temperature the oil can see. ideally the 2nd number is 50.
so if it goes to 0 you actually need 0-40. So like I said, most of the us its never below 20 ever so 20 50 is what you want.
mobil 1 had an ad using the m20 in a 325 where it went a million miles with mobil 1 15 50.
absolutely do not use 5 30 in a m20 engine. in an m42 engine it would work but you will burn out a quart a day.
So I felt moved to post because dulbass monster said everything wrong.
also look for oil that has 1200 ppm of the additive zddp, an aditive that our old cars need but has been removed from modern oil for pollution.
its never on a bottle you have to look it up.
I go for full synthetic if its on sale.... Ive only changed it twice so thats all I know.
20 50 is gonna burn the least and leak the least so thats what Id shoot for first.
as far as transmission oil that was super dangerous advice.
there are 3 versions of the getrag 260, and the difference is the metal the synchronizers use.
each has a tag, look it up.
One needs synthetic oil 75 90 works. it has no tag.
one has a red tag, and it takes atf ( which is like a 10 40 )
one has a green tag, and take regular 80 w.
The synthetic works in the green tag one, but not in the red tag one and vice versa.
I personally used redline mt 90 on mine but royal purple might be similar. Im sure the orignal stuff was mobil 1 75 90w that was the corporate partner then.
stamar is offline   Reply With Quote
Old 04-03-2012, 07:56 PM   #9 (permalink)
Car: 1990 325is E30. Red colour
m20enginebuilder is on a distinguished road
My parts guy at the local BMW dealership told me to use either BMW branded(debranded castrol GTX) 15W40, or Castrol GTX 15W40. Since I could not find Castrol GTX15w40, I put in Castrol GTX 10W40, and it seems to be good in my M20. But since the top end is breaking in, along with a new intermediate shaft bearing, its only gonna be in there for about 1000 miles.
m20enginebuilder is offline   Reply With Quote
Old 04-03-2012, 09:42 PM   #10 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
This is the BMW LL01 oil certification. The oils listed here are approved by BMW:
http://cache.bmwusa.com/Pdf_2861cf6b...5-bf45db277fe8
Also:
"What oil should I use? What is the BEST oil?" - Bob Is The Oil Guy
And: Best BMW LL-01 Approved Oil? - Bob Is The Oil Guy
What exactly is BMW LL01 ? - Bob Is The Oil Guy
Click HERE to see my E36 Blog
2000 328i engine running rough & check engine light on! Anirbas 3-Series (E46, E90) 4 10-10-2010 10:27 AM
BMW Engine Fault alerts when engine revved abruptly bnovenario 5-Series (E12,E28, E34, E39, E60) 3 09-19-2008 02:46 AM
Engine Odor & Service Engine Soon Light 2004 330Ci texas23 3-Series (E46, E90) 1 06-06-2008 09:31 AM
Technical thoughts about engine displacement vs engine output nukeduster 3-Series (E36) 3 02-12-2007 04:28 PM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
