which oil? - BMW Forum - BimmerWerkz.com
Old 10-05-2003, 09:46 PM   #1 (permalink)
quickmike is an unknown quantity at this point
I've had my 1991 325i for about 2 weeks now and am getting the car ready for winter and was wondering which synthetic motor oil to use in it and what weight is best for the 2.5 L engine. It's between the Mobil synthetic and the Castrol synthetic. The winters here in the midwest range on average between 0 F and 40 F.
Any opinions on this would be greatly appreciated.
quickmike is offline   Reply With Quote
Old 10-05-2003, 10:02 PM   #2 (permalink)
I use 10w-40 as do some other E30ers and that seems to work well, although i use castrol gtx high mileage (non-synthetic)
Old 10-05-2003, 10:07 PM   #3 (permalink)
So would the non-synthetic Castrol be better for a high mileage engine? I've got 182,000 miles on it with a slight tapping sound coming from under the valve cover and was thinking a synthetic oil might stop it from tapping (or maybe a valve adjustment?) im not sure.
Thanks for the opinion
Old 10-05-2003, 10:11 PM   #4 (permalink)
i dont know, i guess its worth a shot. non-syn oil is generally better for a higher mileage engine. i would also do a valve adjustment too.
Old 10-05-2003, 10:20 PM   #5 (permalink)
Cool thanks for the info!! As I learn more about this car I hope to help answer other peoples questions as well.
Old 10-06-2003, 12:02 AM   #6 (permalink)
bimmerchic is an unknown quantity at this point
I use castrol gtx too!!!
kali*
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1061429976.jpg' border='0' alt='user posted image' />
bimmerchic is offline   Reply With Quote
Old 10-07-2003, 04:49 AM   #7 (permalink)
m42technic's Avatar
m42technic is an unknown quantity at this point
Send a message via AIM to m42technic Send a message via MSN to m42technic Send a message via Yahoo to m42technic
Non-synthetic oil isn't necessarily better for higher mileage motors. I run Mobil 1 synthetic in my car with 160k miles and I have no problems whatsoever. Just make sure that your engine seals are in reasonable condition.
Synthetic oil isn't going to solve your tapping noise though. Your M20 has mechanical lifters, so valve lash is only adjustable manually. Adjust your valves.
Pretty much just a matter of weather or not you want to spend the extra money for synthetic oil.
<span style='font-size:8pt;line-height:100%'>James
'91 318is</span>
m42technic is offline   Reply With Quote
Old 10-07-2003, 11:09 AM   #8 (permalink)
Fox
Moderator
Send a message via ICQ to Fox Send a message via AIM to Fox Send a message via MSN to Fox
synthetic oils eat through old seals. Its incredibly thin and youll most likely have lots of leaks
Fox is offline   Reply With Quote
Old 10-08-2003, 01:17 AM   #9 (permalink)
m42technic's Avatar
Show me how this is true.
'91 318is</span>
Old 10-09-2003, 03:13 PM   #10 (permalink)
Fox
Moderator
Go put some in an old chevelle see what happens.
Old 10-09-2003, 03:53 PM   #11 (permalink)
m42technic's Avatar
Weeeeeeeeee!!!
'91 318is</span>
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 10:06 PM
