Obc Thermometer Priblems - BMW Forum - BimmerWerkz.com
Old 03-12-2005, 02:37 PM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I drive an 89 325i convertable and a couple days ago I was driving and noticed the on bourd computer said the outside temp was 138 degrees F --- since I live in northern utah and it's march then it's not very likely that the temp is above 40 degrees-------so there's obviously some kind of problem. I un-hooked the battery trying to reset the copmputer but when I hooked it back up then the temp started out realativly close to the right reading but then quickly climbed to 130 or so degrees F---I'd like to know the cause of this ---I pray that I don't need a new computer because I hear those can be pricey----help me please...
yammahamma is offline   Reply With Quote
Old 03-12-2005, 03:36 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
You should check to see where the sensor is. The very end of the sensor should be getting a setady stream of fresh air. I don't remember if your car is like mine in the sensor location('89 325i coupe). My sensor is in the drivers side brake duct. I've seen it before at my work where someone will knock there sensor loose and stick it out of the way up in the front bumper where it gets no fresh air and reads way hotter. This sounds like what is wrong with your car cause if the sensor was broken it would read a negative temp, somewhere arround 20 below.
My M50 Powered E30 Page
Old 03-12-2005, 04:50 PM   #3 (permalink)
CiscoKid's Avatar
make sure the sensor is away from the engine. if it is, you will need a replacement one... they are pretty cheap
or you could be ghetto, and subtract 100 degrees from whatever it says
Old 03-12-2005, 08:57 PM   #4 (permalink)
yammahamma's Avatar
Car: '01 330i
now I've removed my driver side tire and located the sensor-- how the devil do you get the sensor out?? do I have to take the brake off? or can I pull the sensor out?
Old 03-12-2005, 09:10 PM   #5 (permalink)
Your sensor should have come through the bumper or air dam on drivers side. I would clean up the electrical connector at this point and even make a new connector (cut the wires, remove old female connector and then crimp some new bullet style connectors, any auto parts store, and put the two parts together)). I have done this on both fog and OBC temp sensors and solved the incorrect temperature problem.
Need help with my OBC dunkel 5-Series (E12,E28, E34, E39, E60) 1 10-12-2005 11:33 AM
