Notchy Difficult Steering - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 04-12-2005, 12:17 AM Thread Starter
nutcase is an unknown quantity at this point
The steering on my 1985 325e (that I just bought) is very difficult and "notchy". The guy I bought it from told me that it's the steering linkage (U-joint). Seems reasonable, but has anyone else run into this problem? I'm thinking it's a little more complicated because it's so hard to turn the steering wheel, as if the power steering isn't working. Any ideas?
Also, is there a trick to getting the shift knob off? I've pulled up hard, to the point where I'm afraid of doing damage, but it doesn't come off.
Thanks
nutcase is offline
post #2 of 4 (permalink) Old 04-12-2005, 01:48 AM
joshh is an unknown quantity at this point
The steering joint is in the engine bay. Instpect it and let us know. Its a pretty solid joint so I doubt thats the real problem.
Finally pulled the M50 from the donor car.
joshh is offline
post #3 of 4 (permalink) Old 04-12-2005, 03:23 AM
The lower steering knuckles seizing us not unknown but there are other faults that can give the same symptoms even a loose PAS pump belt, the pump or the rack. The only way to test this is to remove the lower steering shaft, then you can feel the knuckle, check the up steering column by turning the steering wheel and you can try the rack etc by turning the pinion with the engine running (you may need to use grips so be very careful of the splines).
If it's a manual then pull harder, if it's an auto there's a 3mm Allen bolt in the handle.
bad man working is offline
post #4 of 4 (permalink) Old 04-12-2005, 11:30 AM Thread Starter
Thanks for the advice. I'll try what you suggest for the steering and let everyone know how it works out. Also, I guess I'll pull harder on the knob (it's a 5 speed).
Later
nutcase is offline
E34 V8 Steering Box Nightmare black_bird_blue 5-Series (E12,E28, E34, E39, E60) 2 02-23-2010 03:18 PM
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Steering Very Stiff theogill 3-Series (E36) 5 12-05-2004 07:17 AM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
U.K.:BMW 530d SE Active Steering Stacy540i Bimmer Talk/Motorsports Talk 0 10-22-2003 09:03 AM
