Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 11-17-2004, 06:02 PM   #1 (permalink)
Idle Member
javieruz's Avatar
Photos: 0
javieruz is an unknown quantity at this point
Send a message via ICQ to javieruz Send a message via MSN to javieruz
when i am accelerating (mainly in the 1st gear but also in the 2nd) around 2000RPM, i can feel this rumbling (also not very strong noise) that transfers to the front seats from around the middle of the car. can that be a bad differential? or some loose bolts? what should i check first?
and by the way. where should a get some cheap manual pump to change the manual transmission oil?
thx.
<span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span>
javieruz is offline   Reply With Quote
Old 11-17-2004, 06:31 PM   #2 (permalink)
Speedy-325is's Avatar
Photos: 0
search the words "guibo" or "flex disk"
you will find the answers. there are topics everywhere if u try looking.
Mark
Old 11-18-2004, 01:44 PM   #3 (permalink)
Photos: 0
viali8 is an unknown quantity at this point
definitly your driveshaft guibo or flexdisc or u-joint. not sure what it is but def. something to do with your driveshaft. i had the same noise in mine too. when i would accelerate it would rumble. but when i was ina higher gear it would stop rumbling. good luck. by the way i had a mechanic do mine he put in a new driveshaft though cost me around 450-500. good luck.
viali8 is offline   Reply With Quote
Old 11-18-2004, 02:18 PM   #4 (permalink)
Idle Member
javieruz's Avatar
Photos: 0
i would search if i knew what i should search for now, i will look into that guibo, flex-disk stuff...
thanks for pointing me into the right direction, hopefully i will not have to replace the whole drive shaft, those things are way to expensive for my budget right now.
i just know that a mechanic, whom i know, did some work on the driveshaft for maybe 500$ some year ago for the previous owner, so i guess it was not a very good job then....
Old 11-18-2004, 03:07 PM   #5 (permalink)
Photos: 0
driveshaft work IS something u can do ur self.......its just a few bolts.
lift up the car
drop exhaust...where applicable
mark postition of shaft to tranny, and diff with tape.
remove shaft
line up new one in the same way the old one came out.
install guibo
put it all together again
vB code is On
What the HELL is making this NOISE???? bimmer_boy 3-Series (E36) 28 01-18-2008 08:15 PM
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-11-2005 12:19 AM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 12:02 PM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 03:25 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
