| No Starting Problem.... a while ago i decide to rebuild the topend and i had the head decked and all new gaskets, i noticed that this one piece on the camshaft was broken... and instead of getting a new 'E' cam i got the "I" cam instead. their for i had to do the extra oil journals. after i had everything done and put back together, i tried starting it, nothing happened so i tried again and she fired right up icon smile. it was runing for a while but really rough... after i starting it and letting it run about 3 times it wouldnt start anymore.....
I cheacked to have all the timing marks lined up, im getting fuel cause when i crank it over it reaks of fuel, im getting spark cause ive checked all the plugs for spark.
I know the injectors are firing cuz the plugs are getting wet from fuel when i crank it...
I havent checked the refrence sensor yet cuz i dont know how to and i just recently found out that sometimes those can be the problem but im not sure... The three relays that are in their own little box i replace and that didnt do anything differant.... i never changed the main relay, that could be the probem too but i dont know, and i dont know witch one it is any way.
- Thanks for all the help-
-Jesse-
__________________ |
