Okay, I am new to the BMW world and new to the forums.
One of my friends have a 1986 BMW 325 and I took it out for a ride and it was love and first drive. After a few months of looking I found one that had been parked for 5-6 years. The timing belt broke and bent two valves. It was a steal since I got it for free just had to fix the guys truck's wiring issues.
Well, on to the issue. I have torn it down and rebuilt it from the block out/up.
After getting the engine back together I sat down prayed and turned the key. It just turned over with out cranking. A few not so nice words later, I started checking to see if I had fuel to the injectors, Yeah. Checked to see if I had spark, nope. I replaced the wires, still nothing. I replaced the Ignition Coil, got some spark, but it is not steady and now I am getting nothing again. I had already checked the relays. I am getting 12v to the coil.
I got it to run once, but I do not have the radiator in for a little more room. So I turned it off. It ran for a good 3-4 min, bother-in-law came over and said hey crank it up I want to hear her. Nothing just the same old turning over.
I am getting spark every now and then. I went to the local junk yard and got a used Electronic Control Unit. I was taking it out and found out that someone had messed with the wiring. I know it goes to the coil, I have traced it back but the bigger Green wire has a inner and an outer wire. not sure how to hook this back up.
Any help will greatly come in handy. I have checked on other forums and they have all failed me.
Have you tried a new coil? Make sure it's earthed well and test the "Low-Tension" wiring to the coil...
This might sound silly but, does the engine-block have a good earthing strap to body attached?
__________________ Eso es todo! Please press the "REP" button if you are happy with your response/answer...
Please JOIN, or just have a look... Its Totally FREE... BMW Part Market
Thank you Dabsy, I have checked it all and after about 3 hours of reading these forums everything went back to the relay. I saw in a post to use jumper wires to check to see if it was working right. Well it was not, I guess someone was messing with them and placed the wrong relay in that spot. I have looked all day today to see if I can find the Relay part number but I have had no luck. So, if anyone can step out to their car and write down the relay part number or where I can find it at PLEASE DO!
Well after finding the part number for the relay, I was able to get her to run. She cut off after about 10 secs but I had a lot unhooked. I have to say that after reading these forums I will not be using another one and will lend my help any way I can. I am new to the BMW world but I have just about gone threw my 1987 325e. Will post some pictures when I get her out of the shop and washed. " if your around Northern SC and you want to paint her for me hit me up"
Well I took her for a drive around the yard today. Just a few minor things. I had a ticking under the hood. I just had to readjust one of the rocker arms. Then I found out my speedometer is not working, so crawled under it and found a small trans leak on a trans cooling line. So if anyone happens to read this and knows what could cause the speedometer not to work, please let me know.
Well off to reading up on the speedometer.........OH WHAT FUN!
