no spark - BMW Forum - BimmerWerkz.com
Old 01-24-2009, 07:33 PM   #1 (permalink)
k.sidlosky's Avatar
Car: 06 Ranger, 03 Accord, 96 m3 s52!
k.sidlosky is on a distinguished road
Send a message via AIM to k.sidlosky
no spark
so the other night I went to leave my sisters house and go to start my car well it just cranked and cranked and cranked so i checked the wires, no spark then moved to the coil wire, no spark swapped out the coil, no spark so i figured it lead to the crank sensor seeing how that was next on the list well it turns out that once I replaced that it still does not start so I had my brother-in-law tow it to my workplace(a garage) and monday I will be going in early any ideas of what I should look for its getting fuel and air just no spark also one of my friends mentioned "cancer" in these cars where the wires rot and create bad grounds but hes not to much of a reliable source
k.sidlosky is offline   Reply With Quote
Old 01-25-2009, 05:13 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Have you checked all fuses.
Old 01-25-2009, 10:34 AM   #3 (permalink)
k.sidlosky's Avatar
yep im afraid that it could be the ecu but hopefully its not
Old 01-25-2009, 11:35 AM   #4 (permalink)
marti5's Avatar
Ok, You may not be getting any power to the DME/ECU, maybe the DME relay has gone,
have you also checked rotor cap and arm.
Old 01-25-2009, 02:15 PM   #5 (permalink)
k.sidlosky's Avatar
most of the ignition system is new with the exception of the coil I'll be sure to check the relay tomorrow
Old 01-25-2009, 02:33 PM   #6 (permalink)
marti5's Avatar
Are you sure the swapped out coil is ok ????
Old 01-25-2009, 02:39 PM   #7 (permalink)
k.sidlosky's Avatar
yeah my brother in law put a blaster coil in his truck a while ago I'll ask him agian im sure we can try a different one
Old 01-25-2009, 03:12 PM   #8 (permalink)
marti5's Avatar
Ok, see if its the coil, if that's good, my next thing would be Camshaft sensor
Old 01-25-2009, 08:06 PM   #9 (permalink)
k.sidlosky's Avatar
I'll be sure to test the sensor tomorrow morning I've got my repair manuel so I'll check before I go to bed on how to test it
Old 01-25-2009, 08:37 PM   #10 (permalink)
so it ran fine and you shut it off and went in for a few hours, then came out and the thing wouldn't fire at all?
silversled is offline   Reply With Quote
Old 01-26-2009, 06:28 AM   #11 (permalink)
k.sidlosky's Avatar
it was having a hard time starting before like earlier that morning I left for work well I had to crank on it more than usual but I figured it was due to the cold
Old 01-27-2009, 04:35 PM   #12 (permalink)
k.sidlosky's Avatar
shes fixed took a risk and replaced the coil she runs fine now put a short shifter in and when I'm in reverse first or second the stick rubs the driveshaft but I'll be able to fix that myself thanks for the help guys
Old 01-27-2009, 06:14 PM   #13 (permalink)
Glad you found your answer!
spark plugs davis_fan 3-Series (E46, E90) 4 12-08-2005 09:31 PM
Help,no Spark denn34 3-Series (E21, E30) 14 02-10-2005 03:59 PM
No Spark emericadna7 3-Series (E21, E30) 0 12-13-2004 05:44 PM
No Spark nsmoore 3-Series (E21, E30) 8 12-08-2004 11:29 AM
SPARK PLUGS daxsandman 3-Series (E21, E30) 6 08-20-2004 08:00 PM
