No Heat! - BMW Forum - BimmerWerkz.com
Old 01-29-2007, 09:31 PM   #1 (permalink)
chap0223 is on a distinguished road
No Heat!
Alright, new to the forum, and I have minimal heat in my 87 325e. It's weird, I have hot heat at a low fan speed (1 or 2) and if I turn the fan up any higher the heat slowly dissipates to cool air. I took it to the dealer and they ran a bunch of tests to verify the operation of the heater core, radiator and heater control buttons. I changed the thermostat, the auxillary t-stat (recall for burning legs), water pump and radiator hoses. Obviously I bled the system after these changes, and added new coolant. What gives?
chap0223 is offline   Reply With Quote
Old 01-30-2007, 08:37 PM   #2 (permalink)
Car: Opening soon:
Sounds like your heater bypass valve is screwed up. You may have to change it.
Old 01-30-2007, 08:47 PM   #3 (permalink)
fporro is an unknown quantity at this point
Send a message via MSN to fporro Send a message via Yahoo to fporro
any tips on how to easily remove this valve ???
cheers,
Frank
e30 parts
fporro is offline   Reply With Quote
Old 01-30-2007, 11:06 PM   #4 (permalink)
Car: Opening soon:
Easy, it's found just above and to the right of your gas pedal. Drain your coolant all the way first or you'll flood your floor with coolant.
Old 01-30-2007, 11:19 PM   #5 (permalink)
well, i was at the yards the other day, found the valve, but was only able to get to the 1 screw facing me.
odd as the others faced firewall and it seems that valve would dismantle instead of dismount. what should i look for ?
3 or more Phillips screws, ?
did you used a stubby screwdriver ??
is the valve a integral part of that whole plastic piece ???
thanks,
Frank
cheers,
Frank
e30 parts
Old 01-31-2007, 09:21 PM   #6 (permalink)
Car: Opening soon:
You remove it as a whole. Remove the center console, then take out the philips head screw of the retaining bracket nearest to the fire wall, then remove the (normally 8mm) head screw going into the heater bypass housing with a 1/4 ratchet. The rest is self explaining.
But before you rip your car apart you should check the hoses on the engine side for kinks and pinches first.
Old 02-03-2007, 09:27 AM   #7 (permalink)
thanks,
I'll give it a try next week.
b. regards,
frank
cheers,
Frank
e30 parts
puller fan not working and Heat.... 98e36bostonchic 3-Series (E36) 20 01-18-2006 01:25 PM
Heat only coming out of drivers side Yankees368 5-Series (E12,E28, E34, E39, E60) 14 12-06-2005 01:12 PM
Removing Heat Sheild Live_the_Curves 3-Series (E36) 9 03-09-2005 11:56 AM
Hey Guys, Just A Quick Question Regarding My Heat bimmerfan620 3-Series (E36) 6 10-29-2004 02:52 PM
no heat 1991 BMW 318i will1506 3-Series (E21, E30) 9 02-27-2004 10:58 AM
