No Coolant To Heater Core, Burrr! - BMW Forum - BimmerWerkz.com
Old 11-27-2004, 03:13 PM   #1 (permalink)
Abbey Normal's Avatar
Abbey Normal is an unknown quantity at this point
Send a message via MSN to Abbey Normal
I have had a problem with my 85 325e running hot, but not overheating and not getting any heat inside the car. I thought it was the thermostat, so after replacing that, I checked the old one, I don't know exactly what temperature it opened at, but it did open. Niether hose going to or from the core is hot. Would backflushing the core be the next thing to try? I looked under the dash trim, and I can see the cable moving when I turn the hot/cold air dial, so it seems like that is not an issue either. All I know is it's getting colder here, and I have to get this figuered out soon. ghead
Any thoughts, suggestions, input, or solutions would be greatly appreciated, thanks in advance.
Abbey Normal is offline   Reply With Quote
Old 11-27-2004, 04:32 PM   #2 (permalink)
idanity's Avatar
idanity is an unknown quantity at this point
okay is the temp. dial on the red part?
is the cable to the temp dial okay?
is the fuse okay?
are all the cables okay?
member of the <span style='colorrange'>3 pedals club</span>
member of the <span style='colorrange'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline   Reply With Quote
Old 12-03-2004, 02:34 AM   #3 (permalink)
is the fuse okay?
[snapback]238485[/snapback]
I can see the cable moving behind the dial if I lay down on the floor and pull back on the console a little bit. I don't really know where to look on the other end of the cable. What fuse would be I be checking? The blower motor works, if that is what you meant.
Old 12-13-2004, 08:35 PM   #4 (permalink)
Tadao is an unknown quantity at this point
I have this same problem...I need help with it too. Takes forever to warm up, but it eventually gets warm after 10-15 minutes inside the car. Also feels like car is overheating in stop and go traffic (OBC temp goes over 30 degrees C and cools back down once i'm up to speed on freeway).
Mark
Mark
1984 325e
Tadao is offline   Reply With Quote
Old 12-13-2004, 09:43 PM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
No, do not back-flush a BMW cooling system, you will create more probles than it will solve. It sounds like at some point someone put stop leak in the cooling system and cloged the radiator and heater core.
My M50 Powered E30 Page
98' e39 electric coolant pump and heater valve controls solenoids scopefrfd OEM Parts 0 09-18-2005 07:56 PM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
Heater Core Problems? emmceethree 3-Series (E21, E30) 0 01-13-2005 12:46 PM
Heater Core Replacement eric wiens 3-Series (E36) 9 10-16-2004 08:10 PM
95 740 heater core gthaler 1,6,7,8 - Series and Mini Cooper 0 06-17-2004 02:35 PM
