my blinkers stopped working about a week ago...so i replaced the relay under the steering column and still nothing. the hazards work fine so i know it's not the bulbs. any suggestions on things i could try
fuse maybe if not there is two relays i believe one for the flasher and one for the blinkers there are fuses for the blinkers as well check that all out
i replaced the relay inside the steering column. and still nothing, any idea on where the other relay is or which one of the fuses goes to the blinkers? any help is appreciated
actually I bet it is the turn signal switch, also run the high beams. mine failed on my 88 325ic so that it would flash brights at on coming traffic if I put a turn signal on...it was the turn signal switch/stalk thing.....
i know where the fuse box is...i was asking which fuse led to the blinkers. also my highbeams still work which is leading me to beleive that it isn't the switch...i could be wrong but i'll trying taking it off and seeing if anything is disconnected. are there different connectors for the highbeams and the flashers or do they run together?
haha what's your car doing 75 miles away? but anyway i did but i had a rust spot in the bottom of my trunk and any time it rained my trunk would get soaked (now fixed) but it was in my trunk the first time it happened and was ruined. is there one online?
well that sucks...i just spent the last of my money on next semester's tuition and a short ram intake. if anyone has a Bentley manual could you look up where the blinker fuses are inside the fusebox. if anyone could do that it would be great
