New Valve Springs - BMW Forum - BimmerWerkz.com
Old 01-25-2005, 07:45 PM   #1 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
I wore out the valve springs with all the shit i did the the motor, that i wasn't supposed to, and want to know which would be the best ones to get. Will the springs out of a i block fit on my e, or is there any others that will fit and handle higher rpms the the e spings.
do i need different rocker arms and shit too. or just the springs
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Old 01-26-2005, 10:38 AM   #2 (permalink)
BimmerKris's Avatar
ANSWER ME
Old 01-26-2005, 10:50 AM   #3 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
Originally posted by BimmerKris@Jan 26 2005, 08:38 AM
ANSWER ME
[snapback]279599[/snapback]
lol, no
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 01-26-2005, 11:02 AM   #4 (permalink)
if you need new springs i would get a new camshaft to you would have to reprogram your chip thou
Old 01-26-2005, 11:17 AM   #5 (permalink)
BimmerKris's Avatar
that would defeat the porpose of my goal
Old 01-26-2005, 12:53 PM   #6 (permalink)
[snapback]279619[/snapback]
how so?
Old 01-26-2005, 04:32 PM   #7 (permalink)
BimmerKris's Avatar
tryin to get power without altering the main internals and besides thats way the fuck out of my budget
Old 01-26-2005, 04:54 PM   #8 (permalink)
oooooooooooooooooooooooooo my bad
Old 01-26-2005, 07:00 PM   #9 (permalink)
Kowalski's Avatar
[snapback]279214[/snapback]
whats your budget looking like? cause you could get new stiffer springs from a local performance shop. and are you sure it is your springs you need to replace? also you can regrind your cam and you dont need to change your computer, it would be ideal to get the most performance out of it but it will notice a big increase even without reprograming.
264* roatation and 388 lift
Old 01-26-2005, 11:34 PM   #10 (permalink)
BimmerKris's Avatar
yeah the springs are right shot, and it throws the valves out pretty quik
Old 01-27-2005, 01:11 PM   #11 (permalink)
Kowalski's Avatar
[snapback]280163[/snapback]
just go buy stiffer valve springs. that way your valves don't float, by the sounds of things you took of the rev limitter, and are planning on reving the crap out of this thing? or is that just me?
Old 01-27-2005, 10:03 PM   #12 (permalink)
Kowalski's Avatar
you could go to the local engine building place and ask them what you should do, they prolly can get you some stiff springs, orwhatever suites your needs. good luck to ya
Old 01-27-2005, 11:36 PM   #13 (permalink)
BimmerKris's Avatar
i can do all the work myself, this car has only seen a shop to be painted. The valve are floating bad, at abour 4300 rpms it used to pull right up to the limiter, but not anymore. I got the rpms up 5300 with a chip, and racing it around all summer, didn't take long to wear out the old vavle spring. I was just gonna put spings off the 2.5L because they are the double spring made to rev up high, but as ling as that is all i need to do the job, then thats all i need to know
Old 01-28-2005, 09:58 AM   #14 (permalink)
Kowalski's Avatar
[snapback]280882[/snapback]
i have no idea if 2.5 springs would work thats why i said go ASK the engine place, i do all my own work also, but im not having any valve floating problems, maybe you have a stickey valve, or lifter?
Old 01-28-2005, 09:16 PM   #15 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
This really doesnt have anything to do with the springs but... If your going to be rebuilding your head you might consider swapping to a euro 323i head as it bolts directly to the 2.7L eta block and boosts compression making about 180 HP.
take in mind that you will need some other parts asociated with the i head such as intake manifold etc.. if i owned an eta i would seriously consider this setup. Its basically like building a 327i.
heres a link explaining everything:
http://www.e21bmw.net/graymarket/library/327i.php
catalyst. is offline   Reply With Quote
325 lowering springs on a 318 jamspeed 3-Series (E21, E30) 2 09-26-2005 10:12 PM
Lowering Springs (h&r Sport Springs) chr328is 3-Series (E36) 17 03-27-2005 01:12 PM
Used M3 Springs docrobot 3-Series (E36) 4 03-09-2005 01:06 PM
Difference: Coil Springs Vs. Coil-over Springs? funtoos 3-Series (E36) 3 02-26-2005 11:46 PM
Why Bother With Aftermarket Springs? jsomogyi 3-Series (E36) 2 02-03-2005 07:11 PM
