new car need help - BMW Forum - BimmerWerkz.com
Old 09-07-2007, 10:35 AM   #1 (permalink)
turbo325e's Avatar
turbo325e is on a distinguished road
new car need help
I just got another 325e buts it a 4 door. the timing belt went on it. I was wondering if it is a easy fix.
thanks.
Manny
turbo325e is offline   Reply With Quote
Old 09-07-2007, 12:43 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
thanks.
Manny
Doing a timing belt for the first time with only hand tools plan on spending about 3 hours on it. Also get a new water pump, front cam seals, distributor cap and rotor, radiator hoses, thermostat, and engine belts.
If the timing belt broke at a min. its going to need the head removed and checked for bent valves. Usually when a timing belt goes on an M20 the engine will need new valves because they hit the pistons and depending on how high the the engine was revving when it broke it can break rocker arms and rocker shaft supports.
My M50 Powered E30 Page
Old 09-07-2007, 09:29 PM   #3 (permalink)
turbo325e's Avatar
it might be 325i but im not sure. would that matter?
Old 09-07-2007, 09:31 PM   #4 (permalink)
turbo325e's Avatar
where did you get your yellow lights from. i've been looking for them.
Old 09-10-2007, 11:29 AM   #5 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
If its a 325i there is usually more damage done to the engine than the 325e because the engines in the "i" cars run a closer tollerance between the piston and valves.
The yellow lights are just Lamin-X covers. Lamin-X then go to store then click on BMW.
Old 09-17-2007, 03:21 PM   #6 (permalink)
turbo325e's Avatar
Do the Auto trans have the sensors on the bell housing? If they do, where are the connectors for the sensers.
Old 09-17-2007, 10:48 PM   #7 (permalink)
turbo325e's Avatar
its a 89 325i. i check the timing belt and its still intact, but a few wires loose and i think i might need to replace the pulse sensor. anything i need to know?
Old 09-17-2007, 11:54 PM   #8 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
nope its pretty straight forward, if the timing belt has not slipped and is still in tact id say its probably not an issue
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 09-18-2007, 07:59 PM   #9 (permalink)
turbo325e's Avatar
OK time belt is intact,but when the engine rotates but the cams don't. could the belt slipped off? is that possible?
Old 09-18-2007, 08:07 PM   #10 (permalink)
turbo325e's Avatar
Old 09-22-2007, 11:21 AM   #11 (permalink)
turbo325e's Avatar
help anyone?
91 m5 Parts car or parting out... trailbuilt For Sale 2 12-12-2007 10:42 AM
You Can Still Buy Warranty For this Car gotoschoolhere Cars For Sale 3 07-03-2007 02:06 AM
