| German torque, gud n tite.
I found these:
Subframe bolts 70 ft-lb
Shock to trailing arm 52-63 ft-lb
Sway bar link to trailing arm 16-17 ft-lb
Brake line unions 7-11 ft-lb
Rear pad carrier to trailing arm 44-49 ft-lb
Rear caliper to carrier 22-25 ft-lb
Upper differential mounting bolts 81-91 ft-lb
Rear differential mounting bolt 59-64 ft-lb
Driveshaft to differential 53 ft-lb
Output flange to drive axle 42-46 ft-lb
Muffler bracket 10 ft-lb
Front exhaust pipe to rear pipe 16-17 ft-lb
Axle nut 144-155 ft-lb |
