Need some info on 1985 BMW 325e - BMW Forum - BimmerWerkz.com
Old 10-21-2003, 08:42 PM   #1 (permalink)
Kool_ZX3 is an unknown quantity at this point
My friend just bought a 1985 bmw 325e, I was wondering what is in the canister that has ZF marked on the top, to me it is power steering fluid but he said it didn't have it.we changed the oil topped up the coolant and brake fluid.The battery is dead right now b/c it won't start.He said it handles really well,pulls good.Doesnt miss at high speeds just is really quiet and runs well.The power windows not work so were trying to figure out if the motor is bad or the fuse is gone, can anyone give us a fuse box diagram and tell us what is in the fluid canister with zf on it.besides that everything looks good.It's been sitting for 2 years and just drievn 16 hours after sittin for so long.So if anyone can give us a hand with everything it be greatly apperciated.
Kool_ZX3 is offline   Reply With Quote
Old 10-21-2003, 10:25 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
The canister marked ZF is the power stearing resv. Be careful when topping of the fluid in this because BMW uses 3 different types of fluid in their power stearing systems. I think your friends car takes regular ATF fluid. As far as the fuse and wireing question go, go and pick up a Haynes manuel should have all the info you need.
My M50 Powered E30 Page
Old 10-23-2003, 02:24 PM   #3 (permalink)
ehlpitel is an unknown quantity at this point
i have e28 528e and the windows dont work, the fuse is fine, so if you figure out how to fix the windows, post it
ehlpitel is offline   Reply With Quote
Old 10-23-2003, 03:03 PM   #4 (permalink)
Here is a link to BEN, BMW E30 Network.
The e30 fuses
http://www.bmwe30.net/cgi-bin/datacgi/data...0046&Section=02
Here is window switch diagnosis
http://www.bmwe30.net/cgi-bin/datacgi/data...0050&Section=02
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 10-24-2003, 11:51 PM   #5 (permalink)
protomor is an unknown quantity at this point
I have the exact same type (85 325e). Ive had some problems with the power windows before. At one point I just yanked the buttons out of the car and cleaned them with some WD40 and/or alcohol.
If that doesnt work try replacing fuses, I have yet to find a place that sells 7.5 amp fuses without being in a huge set and 7.5 seems to be the ones that burn out the most often. I replaced them with 5 amp, theyll burn out faster but its better to have them burn out with a 5 than mess stuff up with a 10.
I dont know much about the steering res but it shouldnt be a big problem to find the proper fluid. Also you mentioned it being quiet, mine can sound fairly loud at higher RPMs, I have a stock muffler but maybe a leak or two in the headers. I like the sound my 325e makes
protomor is offline   Reply With Quote
Lights Inside The Car Issues, 325e From 1985 Limn 3-Series (E21, E30) 1 09-04-2005 05:20 AM
For Sale 1985 325e Mint Condition!! NCav1203 3-Series (E21, E30) 3 05-05-2005 06:22 PM
1985 325e Questions offabroadway 3-Series (E21, E30) 8 03-13-2005 05:30 PM
WTB: Cluster & Seats for 1985 325e Allison Classifieds Sell & Buy 0 02-03-2004 05:34 PM
