yea i try B) , praticing for law shcool as much as i can,,,,,i looked at the schematics and followed all the wires and they seemed fine
here is something that might help figure out what happend ... i had my alternator tested and it was good & battery tesed, also good.... so i get everthing in and i noticed a few things the wire on © was not getting any power..... and as i was testing in i accidently touched the battery lead wire(D) to it and it gave a little spark, so what do you know the cars light go bright and it starts charging so as arcinio hall would say things that make you go "hmmmmm" [while pionting at my temple] and now the wire has power after i take the tester off so by creating that spark it starts to work for some odd reason
..... but it doesnt last it only charges for a little while and then it starts to die again.... so what does that mean is there a bad ground? is that © supposed to be positive power source? i hope somebody can
