| need some advice on 325E NOISE besides this blinker issue, which i figured out. I have this noise coming from the drive train, when the car is on and the car is in neutral. when I engage clutch or (push down clutch) noise disappears. its not a knocking sound more like a winding or whining sound. mechanic said transmission fluid was real low last time he checked. about a month ago. and seems like transmission fluid is kinda leaking. only one or two drops if that after every drive. and its fresh, clean fluid. it does smell like sometimes it is burning tranny fluid after a drive.
I wonder what the problem is. clutch is fine, does not slip. i do need a tune up, new fluids, filters, valve adjustment, starter solenoid, heater valve, brake sensor, brake harness. parking brake pad.
she has new timing belt, thermostat and been resealed in last month.
one other thing before i sent it to my mechanic, and the reason i sent it to him, was during acceleration from 2nd gear to third, reving all the way to 4800 RPM the car would get bogged down at about 3000 rpm. which is maximum torque. it just would not accelerate smoothly through, and seemed to hesitate and then knock into place and continue. I figure that must have been a tranny issue since low fluid was there. my biggest concern or question is if fluid is still burning or leaking then fluid must be low or getting low again. which i need to check. and transmission probably needs to be checked when i get this tune up, pretty soon. just waiting on some extra cash. any thoughts would be appreciated. what component in the transmission would be harmed or damaged because of this and may need to be replaced? |
