Need Power Steering rack advice - BMW Forum - BimmerWerkz.com
Old 07-08-2004, 03:14 PM   #1 (permalink)
seth112 is an unknown quantity at this point
Hello everyone I need a new PS rack. I was curious... should I buy the part online myself and then take it to a mechanic to install? I have a feeling if I let a shop do it all, they will mark up the part price a lot... also does anyone know a ballpark estimate of what this will cost to install?? Happend to anyone else?
seth112 is offline   Reply With Quote
Old 07-08-2004, 03:23 PM   #2 (permalink)
it will probably be a 3hr install, so around $200. the part itself should be in the 300-400 range.
Old 07-08-2004, 07:38 PM   #3 (permalink)
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
I doubt a mechanic would accept your parts. You could buy the best parts in the world and unless u know the guy or something, they probably would not take the parts.
First of all the want to put a mark up on the parts to make money, and second if somethin went wrong with the part and it was the part u gave him, they would blame the mishap on the part rather then mechanic error. I would just take it to the shop and have them buy the part and repair it.
Good luck!!
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 07-08-2004, 07:55 PM   #4 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
it's not that hard to do yourself, it's like 6 bolts and a couple hoses
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Old 07-12-2004, 12:39 PM   #5 (permalink)
Houston is an unknown quantity at this point
If you have average mechanical skills, it is an easy install. I'd advise you to check the tie rods too. You have 2 inner tie rods that may come with a new or rebuilt rack and 2 outer tie rods that will have to be separated from the spindles. It is hard not to tear the rubber boot with the "pickle fork".
I found the hardest part was where the steering attached. Getting that bolt out is easy. Getting the sleeve to slide back on the new stud was harder.
I got a rebuilt one for about $150.00 with a $160.00 core charge. UPS'ing it back was a little hassle. Be sure to save the box the rack comes in for that.
Good luck.
Houston is offline   Reply With Quote
Procrastination Is From The Devil: Power Steering drz 3-Series (E36) 8 04-01-2005 05:02 PM
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 09:32 AM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
Do i really need power steering? ghettozn 3-Series (E36) 17 07-22-2004 07:42 PM
