Need Help With My 85 318i - BMW Forum - BimmerWerkz.com
Old 05-31-2005, 06:53 PM   #1 (permalink)
bimmerboy30's Avatar
bimmerboy30 is an unknown quantity at this point
Send a message via MSN to bimmerboy30 Send a message via Yahoo to bimmerboy30
ghead
My car is running real rich (so i was told) how can i fix this problem? Can it be fixed?
also i upgraded my front rotors to Brembo cross drilled and already had to have them turned once. the front right is making a squeaking noise. the rotors were not zinc coated and i replaced the pads with some auto store cheap brand. is it the rotors, pads or ? Thanks in advance.
<img src=http://www.rankmyride.com/data//7/d/16802//.large/dream_2.jpg> THE ULTIMATE DRIVING MACHINE
bimmerboy30 is offline   Reply With Quote
Old 06-02-2005, 01:08 PM   #2 (permalink)
You’ll have to find out why it’s over-fuelling it could be a few things:
1. Air flow meter baffle sticking
2. Temp sander faulty
3. Fuel pressure to high
4. Injectors leaking
5. ECU fault
Brake squeal is normally the pads not the discs try painting them with copper-grease where they fit into the pad carrier.
Old 06-02-2005, 05:11 PM   #3 (permalink)
77th Gear Member
325eXTATIC's Avatar
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
One other possibility with the rich running issue could be the O2 sensor. If it is faulty you will also probably experience surging, or eratic acceleration amongst other issues though, so take that into consideration.
Just a guess, hope it helps!
Josh
86 325e w/Dinan ECU
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
For Sale: 1984 318i And '85 Non-run Parts 318i mdaitc 3-Series (E21, E30) 4 07-26-2009 12:52 PM
An ALPINA 318i!? I'm I seeing correct? Delmarco 3-Series (E36) 1 09-10-2005 05:09 PM
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 09:32 AM
Under The 318i Hood! 1995 Vs. 1996! Delmarco 3-Series (E36) 13 11-05-2004 08:24 AM
