Need Help, Car Won't Start - BMW Forum - BimmerWerkz.com
Old 02-26-2005, 06:02 PM   #1 (permalink)
adidas_man is an unknown quantity at this point
Send a message via MSN to adidas_man Send a message via Yahoo to adidas_man
i recently bought a 1986 325e bmw from a friend. previously he broke a timing belt and the pistons slapped the valves and did some damage. well he bought a new motor and put it in, and ever since then the car will start but for only about 2-3 seconds then it dies. this is what i've come up with so far, the fuel pressure is good, good compression, base timing is good, and it has good spark. i'm sure it's electrical somehow, but i just have no idea's. has anyone had this problem before with the car starting for a couple of seconds then dying?? or does anybody have any ideas i can try??
Mike Smith
msmith90@charter.net
(660) 619-6453
<u><span style='color:red'>My Rides:</span></u>
92 B20/VTEC Civic Hatch (daily driven)
96 Bone Stock Civic DX (wifey's)
86 BMW 325e (currently not running)
adidas_man is offline   Reply With Quote
Old 02-26-2005, 10:05 PM   #2 (permalink)
sniady is an unknown quantity at this point
Check the mass air flow sensor. That will cause the car to start, and immediatly shut down.
sniady is offline   Reply With Quote
Old 02-28-2005, 11:31 AM   #3 (permalink)
Official Bimmerwerkz Biscuit Distributer
spiff325is's Avatar
Car: 00 M Coupe
spiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud ofspiff325is has much to be proud of
Send a message via AIM to spiff325is
good call, also i remember hearing that the 02 can have something to do with it.
I hate: people who haven't died yet that I hate.
L337 Co-Founding Assistant Executive Director Product Maker of Sunset Sig's Inc.
2000 BMW M Coupe - Dakar-II - S52
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
spiff325is is offline   Reply With Quote
Old 02-28-2005, 07:35 PM   #4 (permalink)
Kowalski's Avatar
[snapback]300988[/snapback]
or a massive vacume leak put a vacume guage on it and see what your getting.
264* roatation and 388 lift
Old 04-02-2005, 03:40 PM   #5 (permalink)
rotaryrox is an unknown quantity at this point
[snapback]299965[/snapback]
Any luck with this problem? I have an 82 320 that has the same symptom. It will start run for a few seconds then die.
How do you test the mass air flow sensor?
rotaryrox is offline   Reply With Quote
Old 04-13-2005, 12:34 PM   #6 (permalink)
richb420 is an unknown quantity at this point
I have the same problem on my 318i after just replacing the head gasket. I have been tyring to figure out this problem for the last 3 weeks. I just cant figure it out! ghead .
If anyone can solve this, please help!!
Rich
[<img src='http://home.comcast.net/~rbakerian/bmw1.gif' border='0' alt='user posted image' />
richb420 is offline   Reply With Quote
Old 04-13-2005, 04:17 PM   #7 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
Rich
[snapback]331537[/snapback]
i doubt its the AFM, you can completely pull the wiring to the AFM and the engine shouldnt die. the check engine will come on, and if you hit the throttle it'll sputter and eventually die after 2-3 seconds of throttle, but if you dont touch the gas a bad afm/no afm will not affect idle.
afm maps are designed to map fuel off-idle.
to check: turn your key to "on" but do not start the vehicle, and then press and release the gas pedal 5 times (wot, let off, wot, let off...) then there will be a 2 second delay and then your check engine light will light up. and then it will start blinking. you can read the ecu trouble codes off how many times it blinks (blink, pause, blink blink, pause, blink blink blink, pause, blink = error code 1231). if its the afm i think it is code 1241? i dont have my manual infront of me at the moment.
if it blinks 1444 then there are no stored trouble codes.
start and then die after 2-3 seconds of running... check your fuel pump.
it might have enough go to pressurize your system with enough fuel to start but isnt pumping fast enough to keep it pressurized to run
just an idea, of where to start.
Old 04-13-2005, 04:41 PM   #8 (permalink)
joshh is an unknown quantity at this point
If you guys get the Bentley service manual, it covers many different thing it could be.
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Old 04-14-2005, 02:36 AM   #9 (permalink)
Its not the fuel pump. I have an adjustable fuel pressure regulator and can keep the car running if I set the fuel at 90 psi. This is however too much fuel and you can smell it coming out of the exhaust. The car normally runs on only about 30 psi.
From what year to what year will the gas pedal test work on. I have a 1985 318i.
Rich
Old 04-14-2005, 09:34 AM   #10 (permalink)
nukeduster's Avatar
Rich
[snapback]332139[/snapback]
1984-1995
have you pulled your spark plugs and checked their condition?
also, how many miles does your cat have on it? if its old, it can get plugged and only allow the engine to run a few seconds before it chokes itself out
Old 04-14-2005, 01:42 PM   #11 (permalink)
[snapback]332214[/snapback]
I checked the plugs and they are terribly fouled due to the system being extremely rich. Cleaned them off and tried to start the car again. Still not go. Starts for 2 seconds then stalls. The cat is only about a year old with only 2000 miles on it and is not pluged because there is plenty of air coming out the tail. The only way to keep it runing is if I set the pressure on the regulator at 90psi. THIS IS WAY TOO MUCH FUEL HOWEVER! I am very tired from trying to figure this out . It seems that no one has ever had this problem!
Rich
Old 04-14-2005, 02:48 PM   #12 (permalink)
nukeduster's Avatar
Rich
[snapback]332364[/snapback]
was the motor that was put in, a new motor or a junk yard pull? when swapped did yuo use the donors engine harness or did you put in a new one?
if so, do you have the old ecu?
Old 04-14-2005, 05:43 PM   #13 (permalink)
Kowalski's Avatar
Originally posted by nukeduster+Apr 14 2005, 12:48 PM--><div class='quotetop'>QUOTE(nukeduster @ Apr 14 2005, 12:48 PM)</div><div class='quotemain'><!--QuoteBegin-richb420@Apr 14 2005, 10:42 AM
Rich
[snapback]332399[/snapback]
[/b][/quote]
sounds like your injectors are plugged, and you need that psi to squeeze out enough fuel to keep the car running...
Old 04-15-2005, 01:49 AM   #14 (permalink)
Originally posted by Kowalski+Apr 14 2005, 04:43 PM--><div class='quotetop'>QUOTE(Kowalski @ Apr 14 2005, 04:43 PM)</div><div class='quotemain'>
Rich
[snapback]332504[/snapback]
[/b][/quote]
Hmmm, it might be the injectors. How do I clean those out. Or do I have to go and buy new ones??
Rich
Old 04-15-2005, 11:27 AM   #15 (permalink)
offabroadway is an unknown quantity at this point
Fuel System Cleaner. Providing your gas tank isn't full (it shouldn't be if you've started the car enough times :P ) put in a bottle of liquid Techron. That might do it. You may want to pull the injectors to get a good look at them though.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 08:32 AM
Why Won't She Start? nicolecass81 3-Series (E36) 4 11-09-2004 05:38 PM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
car won't start euro323 3-Series (E36) 14 03-31-2004 03:42 PM
